05-27-2013 11:36 AM - edited 03-18-2019 01:11 AM
I have been having issues with my C40 that goes into boot loops.
I have not been able to access it from neither web or ssh, only serial connection.
I have tried to load new software to it (twice) as the flash did not have any valid kernel image, but althought I have been successful in uploading the images from TFTP, it still do not want to boot.
Attached output from last update (using tc5.1.7 this time since tc6 didnt work either)
Hope someone can shed some light on this.
Solved! Go to Solution.
05-27-2013 12:26 PM
if you have put the files I attached before in the tftpboot directory where you have the TC package you want to install, you do the same setenv commands as you did before and do :
AMERICA> run reprog
then do a reset to load new u-boot
AMERICA> reset
set your environment again and do the run pkgex as you did with the old u-boot
AMERICA> run pkgex
05-27-2013 11:57 AM
try this. Do this on root privilege: selectsw -v. you see 2 versions and one of them active for example:
1. TC5.1.7 (active)
2. TC5.1.3
then do selectsw 2 and reboot.
05-27-2013 12:01 PM
Ahmad, thanks for your reply.
Issuing the selectsw command does not show any versions.
selectsw -v returns -v is not a directory
Reply on command 'selectsw' is:
yaffs: Mounting /flash
yaffs: restored from chackpoint
05-27-2013 12:04 PM
Hi Øyvind,
just type selectsw and see what you get.
05-27-2013 12:06 PM
yaffs: restored from checkpoint
Nothing more
05-27-2013 12:11 PM
then you can try facotry reset:
05-27-2013 12:07 PM
I would recommend to upgrade the U-boot version too. I am attaching a more recent u-boot and pkgextract.elf files. Put these file in the directory where you have put the package that you loaded before. From the u-boot prompt do the same steps as you did before but instead of doing
AMERICA> run pkgex
do the following instead
AMERICA> run reprog
That should reprogram U-boot and the install the package afterwards.
Danny.
05-27-2013 12:11 PM
Danny, thanks for the updated u-boot.bin
Have updated that now, but do i need to run pkgex after?
05-27-2013 12:16 PM
Hi Oyvind,
Yes, Danny wanted to mention that before you try to push the software via TFTP, it would be a good idea to upgrade the U boot version too.
Once you have done it, please try to the TFTP procedure again and this time we should have better luck. If the codec still fails to boot up. We'd recommend that you open a TAC case where one of the TAC engineers can help out.
Mubashshir Akhtar
TelePresence Solution Group
05-27-2013 12:19 PM
Hi Mubashshir,
I am currently uploading the same image as last tc5.1.7 and will revert with the outcome.
Øyvind
05-27-2013 12:26 PM
AMERICA> run reprog
AMERICA> reset
AMERICA> run pkgex
05-27-2013 12:31 PM
Thanks Danny,
I feel renewed hope here, as it has now started the extraction process, something it skipped totally earlier.
This must be subject to the new u-boot.bin
Will update when finished.
05-27-2013 12:39 PM
Great, seems to have done the trick.
Althought I am only able to mark one post as correct, and that will be Dannys for the updated u-boot.bin, I wish to thank both Ahmad and Mubashshir also for their good help.
To all three of you, I am very impressed with the responce time here, and won't hesitate to use the forums again in the future. Hopefully some day I will be able to help someone else also.
Thanks gents.
Øyvind
