ā06-01-2013 07:50 AM - edited ā07-04-2021 12:09 AM
hi we have aironet 1142
in FR 2.4 all thing is ok and client connect to ap
but in 5 ghz band , in webbase ap show up up but cliend didnt see the ssid of this ap
plz help
thx
ā06-01-2013 08:30 AM
Sorry, I don't understand what you are trying to say.
Are you saying that your AP is in China? If yes, do you have a WLC?
ā06-01-2013 09:23 AM
my problem is FR 5 didnt work ,
ā06-01-2013 09:58 AM
What do mean by "FR 5"?
Sent from Cisco Technical Support Nintendo App
ā06-01-2013 10:08 AM
5 ghz band
ā06-01-2013 10:12 AM
Post your show version and your show run-config
Scott
Help out other by using the rating system and marking answered questions as "Answered"
ā06-01-2013 10:04 PM
System Software Filename: | c1140-k9w7-tar.152-2.JB |
System Software Version: | 15.2(2)JB |
Bootloader Version: | 12.4(23c)JA6 |
interface Dot11Radio1
no ip address
ssid test
antenna gain 0
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6.
m7. m8. m9. m10. m11. m12. m13. m14. m15.
power client 17
channel 5825
station-role root
world-mode dot11d country-code RU both
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
and controller
Radio AIR-AP1140A, Base Address 2401.c774.70b0, BBlock version 0.00, Software ve
rsion 4.10.1
Unused dynamic SQRAM memory: 0x00002B4C (10 KB)
Unused dynamic SDRAM memory: 0x00070B98 (450 KB)
Number of supported simultaneous BSSID on Dot11Radio1: 16
*************Carrier Set: China (UNI3) (CN) (-C)*************
Uniform Spreading Required: No
Configured Frequency: 5825 MHz Channel 165
ā06-01-2013 10:07 PM
Post the output to the command "sh ip int brie".
And remove this line: channel 5825
ā06-01-2013 10:33 PM
ap#show ip int br
Interface IP-Address OK? Method Status Prot
ocol
BVI1 192.168.0.70 YES NVRAM up up
Dot11Radio0 unassigned YES NVRAM up up
Dot11Radio1 unassigned YES NVRAM up up
GigabitEthernet0 unassigned YES NVRAM up up
ā06-02-2013 06:54 AM
post the wlc show run-config no ap
Scott
ā06-02-2013 07:50 AM
Given the filename of the code running "w7" indicates standalone deployment. Your interface output shows the 5GHz radio (Dot11Radio1) on so I'm assuming you just can't "see" the SSID from your station. Look at your config under the dot11 ssid "ssid name" section and look for the config statement guest-mode. This will instruct the ap to broadcast the ssid that you defined. I'm assuming that you have a different SSID configured for each radio given that you "see" the ssid under your 2.4GHz radio. //art
ā06-02-2013 12:41 PM
Haha... Got confused:). Can you post your whole show run-config
ā06-02-2013 05:34 PM
Hello Mehdi,
As per your query i can suggest you the following solution-
Data Rates Supported in Aironet 1140 Series Access Point
802.11a: 6, 9, 12, 18, 24, 36, 48, and 54 Mbps
802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54 Mbps
802.11n data rates (2.4 GHz and 5 GHz):
For more information please refer to the link -
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10092/datasheet_c78-502793.html
Hope this will help you.
ā07-08-2013 10:04 PM
hi this is my config ,
unfortunately i cant work with 5 ghz band yet pls check this thanks
! Last configuration change at 23:23:49 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $
no aaa new-model
ip cef
dot11 syslog
dot11 ssid golestan
authentication open
guest-mode
dot11 ssid golestan2
authentication open
guest-mode
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
no ip address
ssid golestan2
antenna gain 0
station-role root
bridge-group 1
no ip address
ssid golestan
antenna gain 0
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
power client 17
channel 5745
station-role root
world-mode dot11d country-code US both
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.0.70 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 192.168.0.1
snmp-server community cisco RW
bridge 1 route ip
wlccp ap username root password 7 06000A25435C08
wlccp ap wds ip address 192.168.0.3
wlccp wds priority 1 interface BVI1
wlccp wnm ip address 192.168.0.3
line con 0
line vty 0 4
password 7 01300F175804
login
transport input all
end
ā07-08-2013 10:06 PM
Can you please post the following outputs:
1. sh inventory;
2. sh version; and
3. dir
