06-02-2013 02:31 AM - edited 03-07-2019 01:41 PM
All my browsers wait for the web page to get loaded ( waiting for xxxxxxxx.com),even though I have a good internet speed in downloading.Especially when a web address is typed in new tab its just waits too long to get the page to be loaded.
my network is connected to ISP thru their node(cisco 2750),from node its connected to cisco 4500 switch,from there to three firewalls (cisco ASA series ).
Have 16 public IP address ,and in my cisco 4500 a default route is been set to the ISP node
vlan 10
ip address a.b.c.d 255.255.255.240
vlan 100
ip address 1x.1x.1x.6 255.255.255.252
ip route 0.0.0.0 0.0.0.0 1x.1x.1x.5 (Isp node private ip)
kindly respond and help,what configuration have to be done to resolve the slow browsing
06-02-2013 02:52 AM
Hi Chanchal,
Is this a new setup? or was this working fine before?
Were there any changes been made on the device if it was working fine before?
check the CPU , STP and link utilization issues on the switch?
Eliminate the switch , connect the laptop to router and check the speed?
Inayath.
06-02-2013 03:58 AM
Hi Inayath,
Often I faced this problem,In my setup there is no router to connect to the ISP,My ISP provided a 2950 cisco switch as a node,Core 4500 is connected to the node switch thru fiber .From the Core thru port 2/1,.2/2 and 2/3 is connected to three ASA firewalls.and a deafult route is configured with the destination ip in the node switch
2/4 is connected to node ,all other ports are connected to local LAN's.
06-08-2013 10:29 AM
Hi Chanchal,
there can be a number of reasons for slow browsing. i think i have some idea about your setup but the information is very limited. You can try to bypass the ASA for a test client and check if that makes a difference.
Or go through this link to check if the ASA is the cause:
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080b8e100.shtml
A lot of times slow speed is because of slow name resolution. To verify that, you can check this article about DNS server to speed up page load.
It would be best if you share your findings after going through the ASA troubleshooting link above and we can take it from there.
Tanveer
06-08-2013 04:13 PM
I was curious to see if there were any updates to this issue.
I am wondering if further testing was done. What makes you think you have "good" bandwidth speed?
As Tanveer stated, I would eliminate the ASA's and see if speed increases. I'm suspecting a DNS issue myself. Seems like DNS is taking a long time to resolve the name to IP to load the page.
Have you checked speed and duplex settings on each device?
