Dyndns Update Script
Andrea Florio
Hello all,
using the old script to udate Hurricane Electric ipv6 tunnel end point i ended up making this one for dyndns.
the reason why is that lot's of time just a virtual interface goes down and the dns is not updated using the ddns method.
Here is the code:
# EEM policy which updates the ipv4 or DynDNS
# expected syslog messages:
# %HA_EM-6-LOG: ddns.tcl: http request failed
# %HA_EM-6-LOG: ddns.tcl: Response: nochg <ip add>
# %HA_EM-6-LOG: ddns.tcl: Response: good <ip add>
# ddns.tcl
::cisco::eem::event_register_none maxrun 300 queue_priority low nice 0
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
set user "USERNAME"
set pass "PASSWORD"
set fqdn "FQDN"
set url "http://members.dyndns.org/nic/update?hostname=$fqdn&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG"
set auth "Basic [base64::encode $user:$pass]"
set headerl [list Authorization $auth]
if {[catch {http::geturl $url -headers $headerl -queryblocksize 50 -type "text/plain" } token]} {
  action_syslog priority info msg "http request failed"
} else {
  action_syslog priority info msg "Response: [http::data $token]"
exit 0
I would actually want to improve it, adding the myip= argument. This would be needed in case more than one interface needs to be tracked.
i would like to do something like:
set interface "Full interface name"
set url "http://members.dyndns.org/nic/update?hostname=$fqdn&myip=$ipinterface&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG"
i'm just not sure how to do get the ip address of the interface.
Joe Clarke
Best thing to do is CLI commands like you would do manually.  Processing "show interface INTF | inc Internet address is" is a good way to do it.
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_exec $cli1(fd) "show int INTF | inc Internet address is"} _cli_result] {
    error $_cli_result $errorInfo
set _regexp_result [regexp {Internet address is ([\d\.]+)} $_cli_result match addr]
if { $_regexp_result == 0 } {
    puts "Interface INTF does not have an IP address"
    exit 1
set ipinterface $addr
set url ...
# Close open cli before exit. catch {cli_close $cli1(fd) $cli1(tty_id)} result
Joe Clarke
} else {
    exit 1
set url ...
Hello Joseph,
Thank you so much, it's working
that's how the whole script would look like:
set user "USERNAME"
set pass "PASSWORD"
set fqdn "FQDN"
} else {
if [catch {cli_exec $cli1(fd) "show int INTERFACE | i Internet address is"} _cli_result] {
    puts "Interface INTERFACE does not have an IP address"
    exit 1
} else {
exit 0
