06-03-2013 12:24 AM - edited 03-07-2019 01:41 PM
Hi all,
My query is specific to cisco. If i have a SFP+ port in any switch/router etc, can i insert and use SFP port in that ? i recall reading somewhere that SFP+ port is backward compatible with SFP ports.
By backward compatible i mean that we can insert a sfp port in sfp+ port and it will work in 1 G mode. I know that if one end is 10 G and other is 1G it wont work.
Kindly guide
06-03-2013 12:29 AM
Yes. This is supported.
06-03-2013 12:42 AM
Oh good,
Sir is there any Cisco document which i can refer to clients if they ask about it ?
06-03-2013 02:28 AM
1. Go to this website: Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix
2. Search for a switch which has a dual-speed SFP port, like a 2960S-24TD and see what SFP are compatible.
04-29-2021 09:07 PM
I am aware that All Cisco Catalyst switch SFP+ is backward compatible to SFP.
How about SMB switches? (SB or CB Series)
Does it apply the same concept with Catalyst switch?
