06-05-2013 01:31 AM - edited 03-14-2019 11:50 AM
Hi all,
I'm just starting to play with Finesse. Installed version 9.1(1) in the lab and I don't seem to find anywhere in docs how to switch finesse to accept logins by agent name not agent ID. Is it possible at all?
Thanks!
ervins
Solved! Go to Solution.
01-31-2015 05:23 PM
This was supported as of 10.0. There is no setting to change, it just works. Agents can login either with their agent id or their login name.
06-05-2013 05:31 AM
In ICM we can choose login by using agent id or by agent name in CTI OS installation but cisco Finesse server will have communication only with CG or CTI Server and AW server not with CTI OS and hence finesse would require agent to login by using agent ID only.. no other go..
Srinivasan
please rate if this help.
01-31-2015 05:28 AM
2 years have passed. Finesse 10.5. Time to bring up this question again . :)
I still cannot find any setting where I could change login type - ID or agent name. Is it there and I'm just looking in wrong place or it's still not possible?
Thanks!
Ervins
01-31-2015 05:23 PM
02-01-2015 10:24 AM
Thank you for replies, guys.
Hmm.... I'll re-check it in my installation. I started asking this because for me login with ID worked but with agent name didn't. Must be some other reason.
Thank's again!
02-01-2015 04:17 AM
