Warning message
Any chance of LAN ONLY mode
wenyang Wed, 06/05/2013 - 08:23
  • Bronze, 100 points or more
You can set the topology as "UC320W routes voice only" or "UC320W routes voice and data with external DHCP server".
Best regards,
Wendy Yang
wenyang Wed, 06/05/2013 - 19:14
Hi Gavin,
Yes, you can use UC320W as a simple phone system in which UC320W acts as the call agent. You don't have to have the WAN connection.
Best regards,
Wendy
Hello Wendy,
I can't see where I can set the gateway on the Voice VLAN to anything other than the UC320W, nor can I see how I can turn off DHCP for the Voice VLAN.and there is no option to set the WAN connection to none.
Is there a doc to help setup the UC320 as a LAN device only an not the gateway for eithe VLAN.
GT
wenyang Fri, 06/07/2013 - 03:43
Hi Gavin,
UC320W has to act as the DHCP server for the voice VLAN, so that each IP phone can get IP address from UC320W. You can turn off UC320W DHCP server function for data VLAN only, not voice VLAN at Topology page in the configure utility.
WAN connection at UC320W is optional.
Best regards,
Wendy
Simon O'Sullivan Wed, 06/12/2013 - 03:03
Hi Gavin. You can't change the gateway. The 320 is not very flexible for network config. You cant put phones on a remote subnet either. Do you need the phones to have a different gateway anyway?
gonzalezpu Mon, 10/07/2013 - 14:22
I´ve got the same problem. I am trying to register spa phone though the WAN interface instead.
Related Content
