Antenna gain question
bocasierra
We have a 1242 AP and an ANT2506 external antenna. From what I've read I want to use a gain value of 10 for this antenna. However, there will be a 50 ft cable (AIR-CAB050LL) between antenna and access point. Do we need to adjust the gain setting for the cable?
Scott Fella
I would by calculating the loss from the cable and connectors.
-Scott
Here is a link regarding low loss cable
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00801c12c2.shtml
Online calculator:
http://www.timesmicrowave.com/cgi-bin/calculate.pl
Cisco uses LMR-400-DB for <50'
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Ravi Singh
Level 7
Level 7
Scott is absolutely right. Please follow his advice and if you are still facing problem you can contact
a Cisco Aironet partner at: http://tools.cisco.com/WWChannels/LOCATR/jsp/partner_locator.jsp.
They will certainly help you.
