Cisco SPA504G
Jun 6th, 2013
HI there.
I have a Cisco SPA504G phone that is connected to a remote PBX.
I have configured 2 accounts on the phone-ext. 502 and ext. 506, both on the same PBX.
If i activate both accounts, either both become unreachable, or register but are not stable.
If I disable second account 506 and restart phone, 502 stays registered.
I tried setting different UDP ports to register (5061 to 502 to 5062 to 506), tried different settings on my router (Thomson TG585 v7) but nothing help.
I read in some forum about such issue on this phone module and the only work around was-disable second account, which worked.
I need both accounts.
Please advice.
Dror
Dan Miley Thu, 06/06/2013 - 09:02
  • Bronze, 100 points or more
This may be related to NAT on the router,
enable sip-alg on your router (may require a firmware update)
does it work plugged into the cable modem
or possibly forward ports to the phone through the router
sip is usually 5060-5080, (admin-->advanced-->ext x - sip settings --> sip port)
RTP on these devices is usually
16384 to 16538
I think  verify at  admin-->advanced-->sip - RTP parameters --> rtp port min/max
Your voip account provider may have a sample config that will work with your router, and a cisco SPA phone.  The model shouldn't matter, the network settings are very similar between devices.
or call into the small business TAC.  Easiest way is go to
cisco.com/smb  --> support open a case, then once you have your case #  call in 866-6060-1866  Listen to the prompts, pick your language, use "existing case"  opt 2 I think
Hope it helps, please rate helpful posts,
Dan
