Cisco AnyConnect VPN Client with windows 7 64-bit
Jun 7th, 2013
Cisco ASA 5505 - ASDM 6.2(1), ASA 8.2(1)
Cisco AnyConnect VPN Client with windows XP working fine but not windows 7.
I tried both "Cisco AnyConnect VPN Client" and "Cisco AnyConnect Secure Mobility Client" on win 7 - can not connect.
But "Cisco AnyConnect VPN Client" and "Cisco AnyConnect Secure Mobility Client" on win XP - both worked.
Any idea?...
Thank you for your help.
Jessie
guibarati Fri, 06/07/2013 - 12:13
  • Bronze, 100 points or more
What I can tell you is that I have Windows 7 64bits and anyconnect works fine. ver 3.1.03103.
If you feel like share the address for the gateway and I will tell you if it ask for autentication. I don't really think the address is critical information.
It's your call.
jessie@codemed-... Fri, 06/07/2013 - 13:28
it will as for autentication. Also, it work fine with XP. whats your ASDM and ASA?
Thank you
Jessie
guibarati Fri, 06/07/2013 - 13:32
Cisco Adaptive Security Appliance Software Version 8.6(1)2
Device Manager Version 6.6(1)
ASA5515
The ASDM version doesn't really matter. It's just the interface.
jessie@codemed-... Fri, 06/07/2013 - 13:41
error message: "vpn establishment from a remote desktop is disabled."
Thank you
Jessie
Related Content
