06-10-2013 03:37 AM - edited 03-16-2019 05:46 PM
Folks,
I have deplyed Cisco 6921 IP Phones in our production Environment. We are using CUCM v8.5. I have assigned individual user names against ephone-dns. When some one calls a number from his/her extension, he is able to see the dialled number's name. Also the person who is receiving the call, he is able to see the caller's name.
Now i want to see these configured names in ephone-dns in the directory button of every configured Ephones. When i click on the Contacts button on the ephone, i see an error message " Connection Failed" or on some phones it shows "Service Unavailable".
I did some googling but you could not get any hits for this error and hence need your help to rectify these errors.
Thanks!!!!
06-10-2013 04:27 AM
Did configure the directory service under the Telephony service?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_u1ht.html
06-11-2013 01:36 PM
Hi Yahisel2004,
Thanks for the reply, but i am a newbie to VoIP world. I did go through the link sent by you. But it has some many commands that i got completely lost. Can you be specific in terms of commands that need to be executed to make the contacts seen in Individual Ephones.
If you could list down the commands that would enable the end users to see names and corresponding extension numbers when they click on contacts button on their IP Phones, then i can make out.
Appreciate your help in this regards
06-12-2013 09:16 AM
Hi yosh,
Why is it that some of the posts that u had sent have been deleted?
06-12-2013 10:31 AM
I thought you had deleted them... I'm not sure what happened.
Yosh
06-12-2013 09:23 PM
Hi Jaishankar
Are you using CME or CUCM ?
Please remember to rate helpful responses and identify helpful or correct answers.
