SPA525g xml directory
Ian Hamel Mon, 10/07/2013 - 12:34
Here's the file structure I used for my XML directory file (obviously I replaced the names with "NAMEX")  I found this directory to be a bit tedious to maintain as well as really only works for a smaller list of people as it isn't searchable like LLDP is so you'd have to scroll through the entire list.
        Coporate Directory
        Select the User
        NAME1
        7676
        NAME2
        2262
        NAME3
        6035555555
        NAME4
        1041
        NAME5
        3420
I hope that helps!
Ian
r.poweska Tue, 11/19/2013 - 09:34
I use both XML and LDAP, took a little playing around but I got them both to work.
Here are my LDAP settings, make sure you use the FQDN in the Search Base and Client DN
The Display Attrs are how it will search the Containing Directory for the contents
Make sure your XML file is stored in a Web server folder, I used line or ext. 4 as my XML Directory button
Ian's format of the XML file is correct. Depending on your firmware version, you can either of only 32 entries or 96 (this number might be off). the latest firmware supports more than 32 entries.
Hope this helps.
Rich
Related Content
