06-12-2013 09:06 PM
All,
may i know how to manually download the asyncOS 7.5 image then upgrade locally? i using putty to the device to do the upgrade, it was very slow..the upgrade process was for 1 hour, but it still just 20% complete.
06-13-2013 06:11 AM
i set up the web server and upgrade from local server, but when i click upgrade..it will prompt below error
Download error: http://ip address/asyncos/coeus-7-5-0-833/hints/default/1
any idea??
07-25-2013 12:57 PM
I recommend the article below from the Knowledge Base.
Comprehensive Guide to Local Upgrade Servers
https://ironport.custhelp.com/app/answers/detail/a_id/1558/kw/Local%20upgrade/related/1
If the link above does not work, please visit the link below and search for the term.
http://www.cisco.com/web/ironport/knowledgebase.html
I hope this helps.
If you believe this answers your question, please mark the topic as answered.
Thx.
-V
