06-18-2013 12:53 PM - edited 03-07-2019 01:57 PM
Hi all
I'm facing a strange issue on my LAN to a remote site over a layer 2 Ethernet link.
I have a server which shares files, the server runs Linux
If I download a file from the server from the local LAN it's fine.
However if I go to my remote site and do the same it goes from 10 secs to 5 mins to download a 75 mbit file.
However on the remote site if I then download a file from a pc which sits on the same switch and vlan of the server it's fine, the server runs windows.
Any ideas what this could be ?
On the sniffer there seems to be a lot of retransmissions between the 2 devices.
However, as the server is ok from the local LAN, and the remote LAN downloads from another pc ok I'm struggling to find what it could be?
06-18-2013 01:19 PM
How are the two sites connected, MetroE, VPN, MPLS, etc...? What is the connection speed?
06-18-2013 01:30 PM
They are connected via a Ethernet link, 100mbit routed over a vlan
06-18-2013 01:36 PM
Sorry, you already stated that in the original post, "remote site over a layer 2 Ethernet link"
So am I to assume each site has their own VLAN - so each local site is a seperate VLAN?
Are you doing anything with VTP, or intervlan routing on a router? Basically trying to understand the IP flow now.
06-18-2013 01:48 PM
Found another post:
https://supportforums.cisco.com/thread/2129910
This was discussing changes to the MTU, what is your MTU set at?
Here is another post:
https://supportforums.cisco.com/thread/2131109
And then found this too, for what it is worth:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a00801f9eb3.shtml
