Warning message
SHOW ORIGINAL NUMBER ON CALLFORWARD
Jun 20th, 2013
Hello everyone.
I have a customer who wants to forward calls to your mobile phone and he want to see in the display mobile the origin calling number .
The ISDN service provider allows this facility.
Anyone know how to do?
Overall Rating: 5 (1 ratings)
Alexander Maroukian Thu, 06/20/2013 - 16:33
  • Cisco Employee,
Hello Eduard,
If you are using CCA. Under outgoing dial plan. In the ISDN trunk set the caller id only for internal extension not for any.
If you are using CLI just make sure you have calling number initiator under telephony service and that the rule matching the corresponding dial-peer is set to change only the internal extensions.
HTH,
Alex
*Please rate helpful posts
Eduard Trullols... Mon, 06/24/2013 - 11:11
Hi Alexander.
Thanks for your answer but the client wants to see the number of the incoming call initiator.
I have to talk to the service provider to make sure this is allowed.
paolo bevilacqua Thu, 06/20/2013 - 21:32
  • Hall of Fame,
    Founding Member
Eduard Trullols Ripolles wrote:
Hello everyone.
You can take "debug isdn q91" with "term mon" to see which calling number is being sent.
However unless you are in the USA, I doubt that telco will actually allow that.
Eduard Trullols... Mon, 06/24/2013 - 11:18
Hi Paolo.
I'm in Spain, but I have to speak directly to the service provider because the customer is who they say that if allowed but I have my doubts.
Thanks for your answer.
paolo bevilacqua Mon, 06/24/2013 - 11:21
  • Hall of Fame,
    Founding Member
You can check, but is not allowed for sure.
