I want to connect to IPsec VPN on ISA500 by VPN Client (v 5.0.07.0440, the last version, I think), using command line parameters.
I can connect with the command:
"%programfiles%\Cisco Systems\VPN Client\ipsecdialer.exe" -c -user myUser -pwd myPassword "MyConnectionEntry"
but i don't know the command to disconnect from command lines.
If I do
"%programfiles%\Cisco Systems\VPN Client\ipsecdialer.exe" -?
I obtain the list of parameters
vpngui [-c | -sc [sd] [-user <username>] [-pwd <password> ! -eraseuserpwd]] <connection entry>
but I don't unterstand what I have to do... I try every combination using -sd parameter (I think means for silent disconnect), but in every case I can only to show VPN interface without disconnect anything...
Can anyone help me?
