Problem registering movi to VCSe (VCSc working)
thorstenn
Level 4
Level 4
for any reason Jabber Video clients are not able to logon to VCSe. If they are in the office and connecting to VCSc its working.
Deployment:
VCS: 7.2.2
TMSPE: 14.2
VCSc is joined to the domain so people should be able to logon with LDAP credentials. For some days we changed a OU for the users in AD. I resynced the users to TMS. In VCSc my thought is i have nothing to do, right? I don`t no its depending the OU change cause the movi client is not som uch in use.
I started a debug trace on VCSe while logging in from external with movi (IPs and names changed):
SIPMSG:
|SUBSCRIBE sip:<user>@domain.comSIP/2.0
Via: SIP/2.0/TLS 192.168.100.10:3157;branch=z9hG4bK06fbfdf1d928fdea44551eb01444f279.1;received=78.51.4.182;rport=45938
Call-ID: bb23e7fc29870f7a@127.0.0.1
CSeq: 201 SUBSCRIBE
Contact: <sip:<user>@192.168.100.10:3157;transport=tls>
To: <sip:provisioning@domain.com>
Max-Forwards: 70
Route: <sip:79.34.34.123:5061;lr;transport=tls>
User-Agent: TANDBERG/774 (MCX 4.5.7.16762) - Windows
Expires: 300
Event: ua-profile;model=movi;vendor=tandberg.com;profile-type=user;version=4.5.7.16762;clientid="S-1-5-21-176747291-1711663684-1688638919";connectivity=1
Accept: application/pidf+xml
Content-Length: 0
SIPMSG:
|SIP/2.0 404 Not Found
Via: SIP/2.0/TLS 192.168.100.10:3157;branch=z9hG4bK06fbfdf1d928fdea44551eb01444f279.1;received=78.51.4.182;rport=45938;ingress-zone=DefaultZone
CSeq: 201 SUBSCRIBE
To: <sip:provisioning@domain.com>;tag=a9bdf7d526c0cb56
Server: TANDBERG/4120 (X7.2.2)
Warning: 399 79.34.34.123:5061 "Policy Response"
Content-Length: 0
So we have a 404 Not found, but why and what is not found, the user who tried to login? For some reason it looks like the request goes not through VCSe to VCSc, thats my feeling?
Zone Auth is as following:
VCSe:
     DZ: do not check credentials
     TZ: do not check credentials, Accept proxied registrations: deny
     DSZ: do not check credentials, Registration policy: deny
VCSc:
      DZ: check credentials
      TZ: check credentials, Accept proxied registrations: allow
      DSZ: check credentials, Registration policy: allow
I also implemented a CPL on VCSe (not on VCSc) but i also disabled the policy an tried again with no success so this should not be the problem.
I have tested some other constelattion without success. :-( Maybe  someone have an idea what i can test. Could it be a firewall problem?
Thorsten
2 Accepted Solutions
Could you check if the parameter "SIP registration proxied mode" is set to "Proxy to known only" on VCS Expressway? You find that parameter on SIP Configuration.
This is a required parameter to allow VCSe to work as SIP proxy for registration. It is not enough to set "Acept proxied registration" on VCS control. In general, you should have this configuration for proxied registration:
If you don't want to use proxied registration but want jabbers from internet to register directly to VCSe, you should disable proxied registration feature and create SIP domain in VCS Expressway. It would be something like this:
Try this.
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
Try the second option just to check if the problem is really related to proxied registration.
Paulo Souza
40 Replies 40
Paulo Souza
Hi Thorten,
Look at this URI provisioning@domain.com (I am assuming the "domain.com" is your domain). As VCSe does not have Provisioning feature enable, VCSe should take this URI and match it against its search rules, then it should find a search rule that forwards this provisioning message to VCS Control, so that provisioining can occur sucessfully.
So you should check:
Is your search rules ok?
Is the call policy really disable? (See the log: Warning: 399 79.34.34.123:5061 "Policy Response")
Is the traversall zone up? (VCS does not route call to down zone)
Did you try to disable registration policy? (I do see you  have it enable on VCSe)
Paulo Souza
Hi, thanks for help.
@Paulo
Traversal zone is up (h323 and SIP)
Registration policy is set to "none" or do you mean Call Policy? I also tried set to "off" with no difference.
@Alok
Here are my searh rules on VCEe:
LocalSearch
priority: 50
Protocol: Any
Source: ANy
Request must be authenticated: No
Mode: Any alias
On successful match: Continue
Target: LocalZone
TraversalSearch
priority: 100
Protocol: Any
Source: ANy
Mode: Any alias
Target: TraversalZone
DNSSearch
priority: 150
Protocol: Any
Source: AllZones
Mode: Alias pattern match
PatternType: Regex
Pattern string: (?!.*@%localdomains%.*$).*
Pattern behavior: Leave
On successful match: Stop
Target: DNSZone
I don`t know why. But if i now try again it seems to go to VCSc but with a "
SIP/2.0 407 Proxy Authentication Required"
If the provisioning messages are being received in VCS Control, so VCS Expressay is routing correctly. As you have device authentication enable on VCS Control, VCS will try to authenticate the client regardless of the provisioning process. So the local database on VCS Control (imported from TMS through TMSPE or TMS Agent) must to have the users.
Could you check if your local database on VCS Control has the users list? Is the provisioning service replication status ok? Could you run a diagnostic? When users register directly to VCS Control, does it work?
Paulo Souza
407 proxy authentication is expected behaviour when the provisioning is received by VCS control. Since the provisioning messages are receiving by control then run the diagnostic on the control and exp see whats hapening.
does the user you are trying with exist on VCS control ? also some checks can the user is able to register on VCS control when logging from internal lan.
does the provisioning settings on TMS contains public sip server address as your expressway public ip? recheck the user name and password of the user?
if problem persists please open TAC case with diagnostic logs for further analysis.
Rgds,
Alok
Alok Jaiswal
Hi Thorstenn,
404 not found is a response sent by VCS when it can't route the URI to a destination. i believe the issue is related to your search rules configured on the VCS-Exp. we would like to see what search rules you have made on the VCS-Exp.
Also please note that when the initial subscribe message comes it would be user@domain.com and not in form of user.movi@doamin.com. we have seen lot of customers doing this mistake.
so please re-check your search rules on VCS-exp.
Rgds
Alok
thorstenn
Level 4
Level 4
From internal the user can logon without any problems. So The issue have to be between VCSe and VCSc.
On VCSc i see the same 407 proxy authentication issue.
Its strange. The user exist in local database as "TMS" user. Provisioning Services are all active. Tried also a resync.
So maybe some Authentication / Regestration / Proxy settings are not ok on VCSc / VCSe ?
In TMS the external and the internal IP of VCSc and VCSe are configured in the template.
Earlier i postet the Search Rules on VCSe. Could you see some misconfiguration there?
Try this.
Paulo Souza
its exactly configured like this ;(
second option i have to try.
Paulo Souza
Hey Paulo,
second option worked. But why the first not? Is there any reason not show the registered devices on Expressway ?
Do you have any Local Zone --> Subzones on the VCSe where the where the Jabber user actually register to? Maybe ther is something set there with regard to the "Authentication Policy"
In addition, I have found that "example 1" shown above to be slightly incorrect (at least with VCS running x7.2.2).
The SIP domain has to be added to the VCS Expressway even when proxying registrations as the registration actually gets added to the Default subzone on the VCS-E, which also means you also need to ensure that the Default-subzone on the VCS-E "Registration policy" is set to "Allow" (the registration of the Jabber client will be placed into this zone even if you have subzones and membership rules set up)..
Where did you find that information?
The example I posted was taken from the latest Device Authentication Deployment Guide, X7.2. See page 46:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Authenticating_Devices_Deployment_Guide_X7-2.pdf
Paulo Souza
