Linksys wireless access point and 2600 Router
aducey01
Has anyone configured this setup?  Is there a way to secure it?
Thanks!
jeffrrod
Level 4
Level 4
Dear Customer,
Thank you for reaching Small Business Support Community.
What is the Access Point model so that we can provide you the wireless security options available for it. There should not be any particular, special configuration or compatibility issue to connect a 2600 series router to a Linksys AP.
If you wonder about port security options on the 2600 series routers I suggest you to inquire about it on the Network Management Support Community;
https://supportforums.cisco.com/community/netpro/network-infrastructure/network-management
I’ll be looking forward to hear from you.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
