Warning message
QuickVPN at RV110W Wireless-N VPN Firewall
Jun 30th, 2013
Good day,
I try enable VPN remote access from internet trougth RV110W Wireless-N VPN FIREWALL with any result. Please revise my error.
Pertinent information RV110W:
WAN Server Address = 200.124.243.172
LAN Server Address = 192.168.8.111
Routing Operating Mode = Gateway
VPN Client Setting Table = Username Protocol QuickVPN
cert.pem copied into VPN CLIENT Folder
Log QuickVPN Client
2013/06/30 20:52:45 [STATUS]OS Version: Unknown
2013/06/30 20:52:45 [STATUS]One network interface detected with IP address 10.10.10.13
2013/06/30 20:52:45 [STATUS]Connecting...
2013/06/30 20:52:45 [DEBUG]Input VPN Server Address = 200.124.243.172
2013/06/30 20:52:45 [STATUS]Connecting to remote gateway with IP address: 200.124.243.172
2013/06/30 20:52:46 [STATUS]Remote gateway was reached by https ...
2013/06/30 20:52:46 [STATUS]Provisioning...
2013/06/30 20:52:49 [STATUS]Success to connect.
2013/06/30 20:52:49 [STATUS]Tunnel is configured. Ping test is about to start.
2013/06/30 20:52:49 [STATUS]Verifying Network...
2013/06/30 20:52:55 [WARNING]Failed to ping remote VPN Router!
2013/06/30 20:52:58 [WARNING]Failed to ping remote VPN Router!
2013/06/30 20:53:01 [WARNING]Failed to ping remote VPN Router!
2013/06/30 20:53:04 [WARNING]Failed to ping remote VPN Router!
2013/06/30 20:53:07 [WARNING]Failed to ping remote VPN Router!
The remote gateway in not responding. Do you want to wait?
2013/06/30 20:53:10 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2013/06/30 20:53:56 [STATUS]Disconnecting...
2013/06/30 20:54:00 [STATUS]Success to disconnect.
Thanks for your time,
Juan L. Mera
