Bad dequeue error message
Jun 30th, 2013
Hi all,
Could someone please help me with this error message I receive from router logs ASAP?
Syslog logging: enabled (0 messages dropped, 11 messages rate-limited, 110 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 1345 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 1130 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 2133 message lines logged
        Logging to 10.63.9.2  (udp port 514, audit disabled,
              link up),
              2133 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging Source-Interface:       VRF Name:
Log Buffer (8192 bytes):
61D0z 265EF7B0z 23C3A8E8z 23C3A8CCz
Jul  1 04:03:34.241: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 2C89D6D4 -Process= "Crypto Support", ipl= 4, pid= 270
-Traceback= 22E93BE8z 265061D0z 265EF7B0z 23C3A8E8z 23C3A8CCz
Jul  1 04:03:34.241: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 31A09670 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:34.245: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 311ED328 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:34.245: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 31A09670 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:34.245: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 31A0A438 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:34.249: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 2D02D540 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:34.249: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 31A09670 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:34.249: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 2CEC2DF0 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:34.253: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 31A09670 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:34.253: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 2C9018A0 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.073: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=30F9D6AC, count=0
-Traceback= 265EF7A0z 23C3A8E8z 23C3A8CCz
Jul  1 04:03:36.073: %SYS-2-QCOUNT: Bad dequeue 2BAC760C count -1 -Process= "Crypto Support", ipl= 4, pid= 270
-Traceback= 265EF814z 23C3A8E8z 23C3A8CCz
Jul  1 04:03:36.077: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=31C29C7C, count=0
Jul  1 04:03:36.077: %SYS-2-QCOUNT: Bad dequeue 2BAC760C count -1 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.077: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 30F9EB58 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.081: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 2BA944EC -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.081: %SYS-2-QCOUNT: Bad dequeue 2BAC760C count -1 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.081: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 31D955CC -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.081: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 30F9CFC8 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.085: %SYS-2-QCOUNT: Bad dequeue 2BAC760C count -1 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.085: %SYS-2-SHARED: Attempt to return buffer with sharecount 0, ptr= 30F907F4 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:36.085: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=31D4C1D4, count=0
Jul  1 04:03:36.089: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=2BA989D4, count=0
Jul  1 04:03:48.553: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=30F90ED8, count=0
Jul  1 04:03:48.553: %SYS-2-QCOUNT: Bad dequeue 2BAC760C count -1 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:48.553: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=31D22130, count=0
Jul  1 04:03:48.553: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=30F90110, count=0
Jul  1 04:03:48.557: %SYS-2-QCOUNT: Bad dequeue 2BAC760C count -1 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:03:48.557: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=2D27C4FC, count=0
Jul  1 04:03:48.557: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=30F92384, count=0
Jul  1 04:04:00.793: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=2CDB6738, count=0
Jul  1 04:04:00.793: %SYS-2-QCOUNT: Bad dequeue 2BAC760C count -1 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:04:00.793: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=31D96394, count=0
Jul  1 04:04:00.793: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=2BA93E08, count=0
Jul  1 04:04:00.797: %SYS-2-QCOUNT: Bad dequeue 2BAC760C count -1 -Process= "Crypto Support", ipl= 4, pid= 270
Jul  1 04:04:00.797: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=2BA9607C, count=0
Jul  1 04:04:00.797: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=2BA95998, count=0
Jul  1 04:07:27.006: %TUN-4-MTUCONFIGEXCEEDSTRMTU_IPV4: Tunnel81 IPv4 MTU configured 1438 exceeds tunnel transport MTU 1436
Jen
paolo bevilacqua Mon, 07/01/2013 - 06:32
  • Hall of Fame,
    Founding Member
Update IOS and check again.
