Enabling Advanced HTTP application inspection
Answered Question
Jun 30th, 2013
Hi Everyone,
For testing purposes i enable Advanced HTTP application inspection on ASA  globally.
Here is the config
policy-map type inspect http http_inspect_map
parameters
protocol-violation action  drop-connection log
match not response header  content-type application/msword?????????????????????
drop-connection  log
Need to know what does statement with ??????????????? have effect on ASA??????????
Enabled it globally
policy-map  global_policy
class  inspection_default
After doing this i can open first page of any website but after that no other page opens up  here are the logs
Jun 30 2013 20:22:27:  %ASA-6-302013: Built outbound TCP connection 34378 for outside:173.194.33.34/443  (173.194.33.34/443) to DMZ:192.168.70.5/29735  (192.168.71.74/29735)
Jun 30 2013 20:22:27:  %ASA-6-302013: Built outbound TCP connection 34379 for outside:173.194.33.43/80  (173.194.33.43/80) to DMZ:192.168.70.5/29736  (192.168.71.74/29736)
Jun 30 2013 20:22:27:  %ASA-6-302013: Built outbound TCP connection 34380 for outside:173.194.33.50/80  (173.194.33.50/80) to DMZ:192.168.70.5/29737  (192.168.71.74/29737)
Jun 30 2013 20:22:28:  %ASA-6-302013: Built outbound TCP connection 34381 for outside:173.194.33.50/80  (173.194.33.50/80) to DMZ:192.168.70.5/29738  (192.168.71.74/29738)
Jun 30 2013 20:22:28:  %ASA-5-304001: 192.168.70.5 Accessed URL  173.194.33.50:http://t2.gstatic.com/images?q=tbn:ANd9GcRylNXDAKorJERG8q6xKzFCVStYj3R5dqyCHsNoCu__abROPRFFXWFM6z5_y0B_Tm_Ox26cokA
Jun 30 2013 20:22:28:  %ASA-5-415008: HTTP - matched not response header content-type  application/msword in policy-map http_inspect_map, header matched - Dropping  connection from DMZ:192.168.70.5/29737 to outside:  173.194.33.50/80
Jun 30 2013 20:22:28:  %ASA-4-507003: tcp flow from DMZ:192.168.70.5/29737 to outside:173.194.33.50/80  terminated by inspection engine, reason - disconnected, dropped  packet.
Jun 30 2013 20:22:28:  %ASA-6-302014: Teardown TCP connection 34380 for outside:173.194.33.50/80 to  DMZ:192.168.70.5/29737 duration 0:00:00 bytes 382 Flow closed by  inspection
Jun 30 2013 20:22:28:  %ASA-6-106015: Deny TCP (no connection) from 173.194.33.50/80 to  192.168.71.74/29737 flags PSH ACK  on interface  outside
Jun 30 2013 20:22:28:  %ASA-5-304001: 192.168.70.5 Accessed URL  173.194.33.55:http://www.google.ca/s?gs_rn=18&gs_ri=psy-ab&cp=7&gs_id=35&xhr=t&q=rediff.&es_nrs=true&pf=p&biw=1366&bih=622&sclient=psy-ab&oq=&gs_l=&pbx=1&bav=on.2,or.r_qf.&bvm=bv.48572450,d.cGE&fp=f5cabcb9513fcfcb&tch=1&ech=7&psi=4efQUcL1GcPOiwL3wYAg.1372645345226.1
Jun 30 2013 20:22:28:  %ASA-5-304001: 192.168.70.5 Accessed URL  173.194.33.55:http://www.google.ca/gen_204?v=3&s=web&action=&ei=4-fQUd3eMqrpiwL0nYCABQ&e=17259,4000116,4001350,4002693,4002855,4003242,4003881,4004320,4004334,4004844,4004949,4004953,4005865,4005875,4006268,4006426,4006442,4006466,4006727,4007055,4007080,4007117,4007158,4007173,4007230,4007244,4007408,4007445,4007533,4007566,4007661,4007668,4007745,4007762,4007763,4007779,4007798,4007804,4007874,4007886,4007892,4007917,4007927,4007942,4008028,4Jun  30 2013 20:22:28: %ASA-6-106015: Deny TCP (no connection) from 173.194.33.50/80  to 192.168.71.74/29737 flags PSH ACK  on interface  outside
Jun 30 2013 20:22:28:  %ASA-5-304001: 192.168.70.5 Accessed URL  173.194.33.55:http://www.google.ca/s?gs_rn=18&gs_ri=psy-ab&cp=8&gs_id=3j&xhr=t&q=rediff.c&es_nrs=true&pf=p&sclient=psy-ab&oq=&gs_l=&pbx=1&bav=on.2,or.r_qf.&bvm=bv.48572450,d.cGE&fp=f5cabcb9513fcfcb&biw=1366&bih=622&tch=1&ech=8&psi=4efQUcL1GcPOiwL3wYAg.1372645345226.1
Jun 30 2013 20:22:28:  %ASA-5-304001: 192.168.70.5 Accessed URL  173.194.33.55:http://www.google.ca/s?gs_rn=18&gs_ri=psy-ab&cp=9&gs_id=3z&xhr=t&q=rediff.co&es_nrs=true&pf=p&sclient=psy-ab&oq=&gs_l=&pbx=1&bav=on.2,or.r_qf.&bvm=bv.48572450,d.cGE&fp=f5cabcb9513fcfcb&biw=1366&bih=622&tch=1&ech=9&psi=4efQUcL1GcPOiwL3wYAg.1372645345226.1
Jun 30 2013 20:22:28:  %ASA-5-304001: 192.168.70.5 Accessed URL  173.194.33.55:http://www.google.ca/gen_204?v=3&s=web&action=&ei=5OfQUYiCCqbAigKa9ICICg&e=17259,4000116,4001350,4002693,4002855,4003242,4003881,4004320,4004334,4004844,4004949,4004953,4005865,4005875,4006268,4006426,4006442,4006466,4006727,4007055,4007080,4007117,4007158,4007173,4007230,4007244,4007408,4007445,4007533,4007566,4007661,4007668,4007745,4007762,4007763,4007779,4007798,4007804,4007874,4007886,4007892,4007917,4007927,4007942,4008028,4Jun  30 2013 20:22:28: %ASA-5-304001: 192.168.70.5 Accessed URL  173.194.33.55:http://www.google.ca/s?gs_rn=18&gs_ri=psy-ab&cp=10&gs_id=4j&xhr=t&q=rediff.com&es_nrs=true&pf=p&sclient=psy-ab&oq=&gs_l=&pbx=1&bav=on.2,or.r_qf.&bvm=bv.48572450,d.cGE&fp=f5cabcb9513fcfcb&biw=1366&bih=622&tch=1&ech=10&psi=4efQUcL1GcPOiwL3wYAg.1372645345226.1
Jun 30 2013 20:22:28:  %ASA-6-106015: Deny TCP (no connection) from 173.194.33.50/80 to  192.168.71.74/29737 flags ACK  on interface outside
Need to understand the Config in ReD  and logs matched in Red color?
Mahesh
Correct Answer by Julio Carvajal about 4 years 1 month ago
The header content-type should be that one, exactly...Otherwise a drop will happen (as configured)
Remember to rate all of the helpful posts.
For this community that's as important as a thanks.
Hello My friend,
parameters
drop-connection  log
That says:
If the ASA sees a HTTP packet with a header host that does not contain an application/msword header response content it will be dropped.
So in the case you see the drops is due to the fact the response does not contain that header,
Did you configure that just for test purposes or is that what you are looking for
Overall Rating: 5 (2 ratings)
Correct Answer
Julio Carvajal Sun, 06/30/2013 - 22:09
  • Purple, 4500 points or more
Hello My friend,
parameters
drop-connection  log
That says:
mahesh18 Sun, 06/30/2013 - 22:13
Hi Julio,
Just for testing purposes.
So when you say look for header msword does this mean when i open the website like say
www.google.com  it means that this url should have header msword other wise it will be dropped?
MAhesh
Correct Answer
Julio Carvajal Sun, 06/30/2013 - 22:16
mahesh18 Sun, 06/30/2013 - 22:21
Hi Julio,
Thanks for answering my question.
Yes  sir post is rated as usual.
Mahesh
Julio Carvajal Sun, 06/30/2013 - 22:24
Great,
Have a great day Mahesh
