SNMP Critical Process Monitoring
Jul 1st, 2013
I'm Installing a Monitoring service on my environment and it uses SNMP.
Until now I was able to configure the SNMP Agent e Trap for the Devices and it works fine, but it need to be configured with the critical services from each, because now, only the Hardware is monitored.
How do I find the services for each Device or what services should I  monitor?
On my enviroment, I have the follow Devices:
CUCM 8.0
UCCX 8.5
Cisco Video Surveillance
Cisco 3845 Voice Gateway
Cisco 2960 Switch
Any one can Help me with this?
Thanks and best Regards
tony loktu Mon, 07/08/2013 - 03:39
I have the same problem.
The CUCM is the only one i found so far.
I'd like to add CUC 8.5
/Tony
