AnyConnect won't install Linux Ubuntu 13.04
Answered Question
Jul 1st, 2013
Hello all,
I'm trying to install the AnyConnect VPN client on Linux (Ubuntu 13.04) and I've downloaded the vpnsetup.sh script for installation. After granting it permission and running the shell script in terminal, I get this error message:
Installing Cisco AnyConnect VPN Client ...
./vpnsetup.sh: 1: ./vpnsetup.sh: hdid: not found
./vpnsetup.sh: 35: ./vpnsetup.sh: installer: not found
I think the install process is pretty straightforward and I can't think of anything as to why this could be happening. Please let me know what you think.
Thank you!
Correct Answer by nottheoilrig about 3 years 9 months ago
I also need to connect to my office Cisco AnyConnect VPN from Ubuntu 13.04. I installed the "network-manager-openconnect-gnome" package with the Ubuntu package manager and it works well. To configure it (after it is installed) I went to the network menu in the menu bar (where I normally choose my wireless network) and selected "VPN Connections" and then "Configure VPN..."  To install the package you can use the Ubuntu Software Center and search for "network-manager-openconnect-gnome", or you can use the terminal and type "sudo apt-get install network-manager-openconnect-gnome"
Overall Rating: 5 (1 ratings)
Correct Answer
nottheoilrig Wed, 07/03/2013 - 17:15
Michael Muenz Thu, 07/04/2013 - 01:52
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, April 2016
Yes, for Ubutunu OpenConnect is the first choice!
Michael
Please rate all helpful posts
sgiavasis Sun, 07/07/2013 - 21:17
This worked! I can connect using OpenConnect now.
Thanks!
Related Content
