WS-X4612-SFP-E Line card issue
Answered Question
Jul 1st, 2013
I am inserting WS-X4612-SFP-E Card in WS-C4507R-E 7 Slot switch and found this card is detacted by switch but showing unsupported.
I checked on cisco site it is showing this card supported on cisco WS-C4507R-E 7 Slot switch. Plese healp.
Correct Answer by InayathUlla Sharieff about 4 years 1 month ago
Tarun,
You need to upgrade the firmware.
The 4612 line card is supported from 12.2(54)SG or later
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp167668
Table 9     Catalyst 4500 and Catalyst 4900 Switches Support
Platform
Switch or Module
Transceiver Module
Minimum Software Release Required
Cisco IOS Support
DOM Support
WS-X4612-SFP-E
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-SX-MMD
GLC-LH-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
DWDM SFP
DWDM SFP (add.)
GLC-EX-SMD
12.2(54)SG
12.2(54)SG
15.1(1)SG
12.2(54)SG
15.1(1)SG
Inayath
******Please rate all usefull posts*********
Overall Rating: 5 (1 ratings)
InayathUlla Sharieff Tue, 07/02/2013 - 00:40
  • Cisco Employee,
Cisco Catalyst 4500 46xx E-Series Line Cards
24 Gbps
Cisco Catalyst 4503-E, 4506-E, 4507R-E, 4507R+E, 4510R-E, and 4510R+E1
Supervisor Engine 8-E,
Supervisor Engine 7-E,
Supervisor Engine 7L-E,
Supervisor Engine 6-E,
Supervisor Engine 6L-E
Kindly check the sup module which you have on this device.
Inayath
*Plz rate all usefull posts.
Tarunkumar Vyas Tue, 07/02/2013 - 04:40
I am using  Supervisor Engine 6L-E,
Below snap Sup module as well as showing line module detail.
Correct Answer
InayathUlla Sharieff Tue, 07/02/2013 - 04:49
  • Cisco Employee,
Tarun,
Platform
Switch or Module
Transceiver Module
Cisco IOS Support
DOM Support
WS-X4612-SFP-E
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-SX-MMD
GLC-LH-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
DWDM SFP
DWDM SFP (add.)
GLC-EX-SMD
12.2(54)SG
12.2(54)SG
15.1(1)SG
12.2(54)SG
15.1(1)SG
Inayath
Titusthuku Sat, 02/01/2014 - 07:44
Hallo Tarun,
I have same scenario of unsupported module.
I upgraded from cat4500-entservices-mz.122-44.SG1.bin  TO   cat4500-entservices-mz.150-2.SG8.bin for 4612 card support.
see below
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICES-M), Version 15.0(2)SG8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 02-Dec-13 17:08 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x121B3BD0
ROM: 12.2(31r)SGA1
Dagobah Revision 226, Swamp Revision 32
XXXXXXX uptime is 40 minutes
Uptime for this control processor is 23 minutes
System returned to ROM by reload
System image file is "bootflash:cat4500-entservices-mz.150-2.SG8.bin"
#show module
Chassis Type : WS-C4507R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1     0  Unsupported module                     WS-X4612-SFP-E     XXXXXX
Should I downgrade to cat4500-entservices-mz.122-54.SG1.bin ?
Or
Does the card require from supervisor 6 to be supported
