Warning message
Teck Chye Tang Tue, 07/02/2013 - 00:39
  • Cisco Employee,
Cisco Performance Mic 20 Specifications
  • Intuitive mute function directly on microphone with status indicator
  • Omni-directional, boundary microphone.
  • Excellent RF resistance and low self noise.
  • 3.5 mm four-pin mini-jack connector and 7.5 meter cable.
  • Robust and well suited for long-term meeting room use.
  • Designed by Cisco.
Technical details:
  • Directivity: Omni-directional (uniform in hemisphere above boundary)
  • Frequency response: 80-15 kHz | 80-3 kHz ± 3dB | 80-15 kHz ± 6dB
  • Sensitivity: -35dB ±3dB rel. 1V/Pa.
  • Max SPL: 110dB (3% THD @ 1kHz)
  • Self-noise: < 29 dBA , > 65 dB SNR (Signal to Noise Ratio)
  • Mic. output: Differential
  • Phantom power: 12 V
  • Output connector: 4 pin 3,5 mm mini-Jack (Shield: GND / ring 2: muter detect / ring1: signal - / Tip: signal +)
robert.ramlall@... Wed, 06/11/2014 - 11:07
Is there an extension cable from Cisco (male to female) for these mics and if so, is there a length restrictions before any issues occur that would affect quality or functionality?
If there's a Cisco extension please provide the part #.
Wayne DeNardi Wed, 06/11/2014 - 16:59
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 TelePresence
Yes, there is a 10m extension cable available from Cisco, part number is CAB-MIC20-EXT=.
The microphone and cable were only designed for a single extension cable, however, if you make your own extension with quality cabling (22/4 gauge shielded audio cable) and connectors you can get a longer distance (length will vary depending on the voltage drop characteristics of the cable you choose).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
