07-02-2013 12:48 AM - edited 03-04-2019 08:21 PM
Hi Everyone ,
here is a scenario i have two Internet lines. ADSL and Internet Leased Line.
Adsl is configured as Wan1 Interface and ILL is configured as WAN2 interface in my router. i have static and route-map configred as mentioned below.
static route = 0.0.0.0 0.0.0.0 wan1
Route-map = src(0.0.0.0/0.0.0.0) dst(0.0.0.0/0.0.0.0) port(80,449) gateway(wan2)
i want to know users are getting an internet by which interface (wan1 or wan2) ?. Does route-map takes precedence over static route.
thank you .
regards,
IT
07-02-2013 01:09 AM
Yes, Policy based routing takes precedence over static or dynamic routes only when match occured. If the statement is marked as permit and packets meet match criteria are all set clauses are applied. If does not meet the match criteria packets are forwarded by normal routing process.
If you want to check you may see your current public IP by using web sites like this:
Hope it will help.
Best regards,
Abzal
07-02-2013 01:16 AM
Hi Abzal,
thank you for you quick reply. yes indeed (http://www.whatismyip.com) shows me ADSL(WAN1) interface IP, but when i do traceroute towards www.google.com or any website it clearly shows it traced through ILL(WAN2) interface IP.
I HOPE YOU WILL HAVE THE SOLUTION OF MY PROBLEM.
regards,
AAMIR
07-02-2013 01:22 AM
Hi Aamir,
Can you post your router configuration? And explain what are you trying to achieve?
Hope it will help.
Best regards,
Abzal
07-02-2013 01:31 AM
Hi Abzal,
i just want to know are users getting an internet thorugh ADSL or ILL by looking at the configuration down below. All these configuration is done on Fortigate Firewall.
Policy-routing = src(0.0.0.0/0.0.0.0) dst(0.0.0.0/0.0.0.0) port(80,449) gateway(wan2)
regards,
AAMIR
07-02-2013 05:28 AM
I think it's better to ask on Fortigate's tech forum or their tech support.
Hope it will help.
Best regards,
Abzal
