Warning message
Guest Wireless with Web Portal
Jul 2nd, 2013
I have my guest wireless accepting terms through a web portal, but it seems they have to accept these terms about every 30 minutes to an hour to get access to the internet again. They are not idle, their session just stops working, and when they open a new browser it redirects them to the web portal. Is there a timer for this somewhere that I am missing?
Scott Fella Tue, 07/02/2013 - 04:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You have two timers... one is the session timeout which is configured in the WLAN advanced tab.  I usually set that to 8 or 12 hours.  Then on the Controller tab in the GUI, you have an idle timer, I would set that to 2 (7200 sec) hours or 4 (14400 sec) hours.  Give that a try.  With newer code versions, you can set the idle timer on the WLAN and not have to touch the global setting.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
mmangat Tue, 07/02/2013 - 19:14
From the Lifetime drop-down lists, choose the amount of time (in days, hours, minutes, and seconds) that this guest user account is to remain active. A value of zero (0) for all four text boxes creates a permanent account.
Default: 1 day
Range: 5 minutes to 30 days
Note The smaller of this value or the session timeout for the guest WLAN, which is the WLAN on which the guest account is created, takes precedence. For example, if a WLAN session timeout is due to expire in 30 minutes but the guest account lifetime has 10 minutes remaining, the account is deleted in 10 minutes upon guest account expiry. Similarly, if the WLAN session timeout expires before the guest account lifetime, the client experiences a recurring session timeout that requires reauthentication.
Note You can change a guest user account with a nonzero lifetime to another lifetime value at any time while the account is active. However, to make a guest user account permanent using the controller GUI, you must delete the account and create it again. If desired, you can use the config netuser lifetime user_name 0 command to make a guest user account permanent without deleting and recreating it.
For more information, Please check the following cisco doc:
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70users.html
Shaoqin Li Wed, 07/03/2013 - 09:31
  • Bronze, 100 points or more
Did the client roam? I don't think it is some session timeout or idle timeout issue if client did not hibernate. also nothing to do with client life time.
get debug client for the real reason why it is back in webauth_req status.
btw if radio get reset the issue may also happen, but again first get debug client
Scott Fella Wed, 07/03/2013 - 10:36
  • Hall of Fame,
    2017 Wireless
WebAuth and Apple devices when the screen sleeps, typically that's when the idle timer starts. This is a know issue when using WebAuth and you have iPads or iPhones. The idle timer needs to be increase or else you will have to login every 5 minutes which is the default timer. That is after the iPad or iPhone sleeps. Passthrough also will request you hit the accept button.
Just look at the client status in the WLC. If you see the idle timer counting down, then you will eventually not see the client once it expires. This means you have to login again.
JASON SIMMONS Thu, 01/23/2014 - 10:16
Scott
Where do I go to view the idle timer? All I see on the Clients detail page is UpTime and Timeout values.  UpTime time is raising while the Timeout value is static.
running version 7.4.110.0 on a 5508.
Scott Fella Thu, 01/23/2014 - 18:17
  • Hall of Fame,
    2017 Wireless
Jason,
I think I was looking at the sleeping client feature.... I was looking at it again and did notice that after the idle timer expired and when using sleeping client, the client mac address would appear on the sleeping client section and that would start counting down.  There isn't a value for the idle timer, which would be nice though.
Scott
JASON SIMMONS Thu, 01/23/2014 - 21:00
Thanks.  I opened a case and learned that option is in v7.5. There was a reason why we didn't jump from 7.3 to 7.5 now I have to remember why.
JASON SIMMONS Sat, 02/01/2014 - 10:38
I installed v7.5 configured the sleeping client feature and I'm not getting the desired result.   My test device (Ipod model MD067LL/A) isn't being added to the sleeping clients list.  I saw the following in the configuration guide.
  • The authentication of sleepling clients feature is not supported with Layer 2 security and web authentication enabled.
I don't think that applies to my situation.
The WLANs configuration is below.
WLAN Identifier.................................. 4
Profile Name..................................... xxxxxxxxxx
Network Name (SSID).............................. xxxxxxxxxx
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 0
Exclusionlist.................................... Disabled
Session Timeout.................................. 36000 seconds
User Idle Timeout................................ 300 seconds
Sleep Client..................................... enable
Sleep Client Timeout............................. 8 hours
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... xxxxxxxxxxxxxxx
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ xxxxxxxxxx
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
    PMIPv6 NAI Type.............................. Hexadecimal
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Disabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Enabled
        IPv4 ACL........................................ Unconfigured
        IPv6 ACL........................................ Unconfigured
        Web-Auth Flex ACL............................... Unconfigured
        Email Input..................................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Disabled
   Client MFP.................................... Disabled
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
Scott Fella Sat, 02/01/2014 - 10:54
  • Hall of Fame,
    2017 Wireless
With sleeping clients, it only works with layer 3 using WebAuth. Since you have a layer 2 and passthrough, you device will not be out into the sleeping client role. It will only work with layer 2 being open and layer 3 using WebAuth.
Scott Fella Sat, 02/01/2014 - 11:01
  • Hall of Fame,
    2017 Wireless
Just create a test SSID with WebAuth so you can see the process. Once the idle timer expires, the client will be put in the sleeping client.
Trending Topics - Security & Network
