Warning message
Bundle 2 x 1GBPS lines?
Answered Question
Jul 2nd, 2013
I am trying to find a solution of getting throughput of 1.5 Gbps over VPN through the internet.
I have found the ASR can do this throughput with the right card.
Does anyone know if you can bundle 2 of the interfaces for site to site vpn and then use EIGRP to equal cost load balance over the gig lines?
Have contacted our supplier and they say it can't be done and must go 10Gbps.
Internet access in the UK for a 10Gbps interface would cost a fortune so am not even considering it at the moment.
Any help greatly appreciated..
Correct Answer by mfurnival about 4 years 1 month ago
I can't give you a definitive answer but logically you would expect EIGRP (or whatever) to see the routes as equal cost and load balance the traffic. Might be one to test in GNS3 before you commit to anything.
Overall Rating: 5 (1 ratings)
mfurnival Tue, 07/02/2013 - 08:24
  • Silver, 250 points or more
I don't think you can bundle the interfaces for the VPN but you could create two VPN tunnels in parallel and load balance the traffic over them using the routing protocol of your choice.
splickman Tue, 07/02/2013 - 08:31
Yes sorry that is what i meant, 2 gig lines with 2 vpn tunnels over them with the same setup at the other end.
So its just whether the ASR will distribute the vpn load over the 2 VPN tunnels.
Correct Answer
mfurnival Tue, 07/02/2013 - 08:34
