07-02-2013 09:00 AM - edited 03-16-2019 06:11 PM
Hello all,
I'm planning to perform some jump upgrades from CM 7.1(3a) to CM9.1(2) as described from Cisco during the last 20 days.
I would like to know, if possible:
- what is the expected release date for CM version 9.1(2)?
End of June, first days of July...
Can you provide a date?
thanks
lorenz
have a look to my blog lgrconsulting.com
07-02-2013 09:28 AM
What is the Hardware u are using for 7.1(3) and what is the new H/w for 9.x
For dates, u can speak to Cisco SE.
regds,
aman
07-03-2013 12:58 AM
7.1(3a) is on MCS
9.1.2 will be a virtual deployment on UCS
any ideas for dates? My SE is not of any help...
07-03-2013 03:28 AM
Need to know the exact MCS model. 7.1(3) to 9 .x jump upgrade is possible provided MCS H/W supports .
You can refer Drive to 9
regds,
aman
07-03-2013 06:31 AM
Release dates/roadmap items/future features, etc cannot be discussed here, that's the reason Aman directed you to your SE/AM, which is the right thing to do.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
