Warning message
VPN Connects but unable to access internal devices
Answered Question
Jul 2nd, 2013
Thank you in advance for any assistance that can be provided.
I am using AnyConnect to create a VPN with an ASA 5505.  Once connected, the client needs to access a device behind a 1941 router.
Internally, (not using VPN), all my routing is working correctly.  My VPN client can connect and when I put a route on my 1941 router, I am able to ping that particular device.  But my VPN client cannot appear to ping anything else, either the devices on the same internal range as the ASA 5505 or anything past the 1941.
VPN Client                                      ASA 5505                                      Workstation                    1941 Router                        Far Device
192.168.201.20 ----->   Outside IP x.x.x.x // Internal 192.168.101.1          192.168.101.56        192.168.101.2 // 192.168.8.1          192.168.8.150
Client connects and get IP from ASA
        Cannot ping this                                                            Cannot ping this
        Can ping internal IP of 1941
        *(after creating a static route)
I have been playing around with my configuration extensively to try and make this work.  Split-tunneling is enabled and is required.
Here is my current config:
hostnameMYHOST
enable password mUUvr2NINofYuSh2 encrypted
passwd UNDrnIuGV0tAPtz2 encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.101.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.0.0
interface Vlan7
no forward interface Vlan1
nameif DMZ
security-level 20
ip address 137.57.183.1 255.255.255.0
ftp mode passive
clock timezone MST -7
dns domain-lookup outside
object-group network obj_any_dmz
access-list nonat extended permit ip 192.168.101.0 255.255.255.0 any
access-list nonat extended permit ip 192.168.201.0 255.255.255.0 any
access-list split-tunneling standard permit 192.168.101.0 255.255.255.0
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
ip local pool Internal_Range 192.168.101.125-192.168.101.130 mask 255.255.255.0
ip local pool vpn_pool 192.168.201.20-192.168.201.30 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0
nat (DMZ) 10 137.57.183.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
route inside 192.168.8.0 255.255.255.0 192.168.101.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable 64000
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint ASDM_TrustPoint1
enrollment self
subject-name CN=MYHOST
keypair ClientX_cert
crl configure
crypto ca certificate chain ASDM_TrustPoint1
certificate 0f817951
    308201e7 30820150 a0030201 0202040f 81795130 0d06092a 864886f7 0d010105
    05003038 31173015 06035504 03130e41 494d452d 56504e2d 42415455 53311d30
    1b06092a 864886f7 0d010902 160e4149 4d452d56 504e2d42 41545553 301e170d
    31333036 32373137 32393335 5a170d32 33303632 35313732 3933355a 30383117
    30150603 55040313 0e41494d 452d5650 4e2d4241 54555331 1d301b06 092a8648
    86f70d01 0902160e 41494d45 2d56504e 2d424154 55533081 9f300d06 092a8648
    86f70d01 01010500 03818d00 30818902 818100c9 ff840bf4 cfb8d394 2c940430
    1887f25a 49038aa0 1299cf10 bda2a436 227dcdbf f1c5566b c35c2f19 8b3514d3
    4e24f5b1 c8840e8c 60e2b39d bdc0082f 08cce525 97ffefba d42bb087 81b9adb9
    db0a8b2f b643e651 d17cd6f8 f67297f2 d785ef46 c3acbb39 615e1ef1 23db072c
    783fe112 acd6dc80 dc38e94b 6e56fe94 d59d5d02 03010001 300d0609 2a864886
    f70d0101 05050003 8181007e 29e90ea0 e337976e 9006bc02 402fd58a a1d30fe8
    b2c1ab49 a1828ee0 488d1d2f 1dc5d150 3ed85f09 54f099b2 064cd622 dc3d3821
    fca46c69 62231fd2 6e396cd1 7ef586f9 f41205af c2199174 3c5ee887 42b684c9
    7f4d2045 4742adb5 d70c3805 4ad13191 8d802bbc b2bcd8c7 8eec111b 761d89f3
    63ebd49d 30dd06f4 e0fa25
  quit
crypto isakmp enable outside
crypto isakmp policy 40
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 DMZ
ssh timeout 10
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl encryption rc4-md5 rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
ssl trust-point ASDM_TrustPoint1 outside
webvpn
enable outside
svc image disk0:/anyconnect-win-2.4.1012-k9.pkg 1
svc enable
group-policy ClientX_access internal
group-policy ClientX_access attributes
dns-server value 4.2.2.2
vpn-tunnel-protocol svc
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split-tunneling
default-domain value access.local
address-pools value vpn_pool
ipv6-address-pools none
webvpn
  svc mtu 1406
  svc rekey time none
  svc rekey method ssl
username ClientX password ykAxQ227nzontdIh encrypted privilege 15
username ClientX attributes
vpn-group-policy ClientX_access
service-type admin
tunnel-group ClientX type remote-access
tunnel-group ClientX general-attributes
address-pool Internal_Range
default-group-policy ClientX_access
tunnel-group SSLClientProfile type remote-access
tunnel-group SSLClientProfile general-attributes
tunnel-group ClientX_access type remote-access
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:da38065247f7334a5408b7ada3af29ae
: end
Correct Answer by Karsten Iwen about 4 years 1 month ago
ok, lets go on ... ;-)
Split-Tunneling: The ACL must include all networks you want to reach through the VPN:
access-list split-tunneling standard permit 192.168.8.0   255.255.255.0
NAT: Don't use "any" in the nat-exemption, but specify all traffic that should not be natted:
access-list nonat extended permit ip 192.168.101.0 255.255.255.0 192.168.201.0 255.255.255.0
access-list nonat extended permit ip 192.168.8.0   255.255.255.0 192.168.201.0 255.255.255.0
Routing: The 1941 needs a route for the vpn-pool pointing to the ASA (just in case there is no default route to the ASA)
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Overall Rating: 5 (1 ratings)
Correct Answer
Karsten Iwen Tue, 07/02/2013 - 12:38
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
Lemon Lime Tue, 07/02/2013 - 13:22
Okay.....I gave that a shot but still not happening.
I put a route on the 1941, which I can ping successfully.  I cannot seem to ping anything else on my internal network or anything past the 1941.
Here's the updated short config:
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
arp timeout 14400
Lemon Lime Tue, 07/02/2013 - 14:12
Oooops!!
I am a big fat liar.  I can actually ping my internal network!  Hurrah!!
Unfortunately I stil cannot ping anything the otherside of my 1941.  I have confirmed that internally all the routing is fine.  I can ping from my VPN client to the interface of the 1941 (192.168.101.2) but then nothing seems to happen after that.
Any suggestions on debugs I can run?
Again, many thanks for your assistance.
Karsten Iwen Tue, 07/02/2013 - 14:32
Do a "debug ip icmp" on the 1941 and ping the remote IP (192.168.8.1) of the router. Do you see any output? And paste the config of the router.
Lemon Lime Tue, 07/02/2013 - 15:48
Nothing appeared on the 1941 when pinging anything on the other side  of the device, which lead me to believe it was a ASA firewall issue.
I have it working.  I did some research and playing  around and for anyone else who looks at this in future I added these two  lines to my config:
access-list outside_access_in extended permit ip 192.168.201.0 255.255.255.0 192.168.8.0 255.255.255.0
access-group outside_access_in in interface outside
Karsten, many thanks for your help.  You Sir are a Gentleman and a scholar or as the kids say "you da man".
