Warning message
Cisco Emergency Responder and Microsoft Lync
Answered Question
Jul 2nd, 2013
Hello All,
I have a customer that has CUCM and CER, but they are also doing Microsoft Lync SIP Phones in a number of locations on the same site. Lync is connected to CUCM via a SIP trunk. I am wondering what (if any) possibilities there are to route accurately 911 calls from Lync phones via the appropriate ERL through CER.
CUCM 7.1.5 upgrading to 9.1
CER 7.1 upgrading to 9.1
Thanks in advance for your assistance.
Correct Answer by Chris Deren about 4 years 1 month ago
No, this is not possible as Lync will not be discovered by CER as it is not registered to CUCM, nor using CDP. I don't think subnet based tracking would work either.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Tue, 07/02/2013 - 12:26
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
gregorysco Tue, 07/02/2013 - 12:32
Thanks Chris,
I was hoping that there would be something not so abvious that I might be able to "hang my hat on", but as you identified, there's really nothing to associate to. Thanks,
Jonathan Schulenberg Sun, 07/07/2013 - 13:15
    2017 IP Telephony
What about Manually Configured Phones which relies solely on the ANI of the calling party? It's at least worth a shot. One gotcha I can see here though is that Lync loves E.164 and CER doesn't support the plus character yet. You would need to localize the CgPI before the call arrives at CER.
Please remember to rate helpful responses and identify helpful or correct answers.
