Warning message
SNMP Configuration on Cisco 6500, 4500 Series Switches
Jul 3rd, 2013
I need some technical Confirmation regarding SNMP Configuration in Cisco 6500 & 4500 series:
Here is way to configure SNMP on Cisco 4500 series switches and also 3750, 2960 Series of Switches:
Switch(config)#snmp-server enable traps
Switch(config)# snmp-server community cisco rw
Switch(config)# snmp-server host cisco.com version 2c cisco
I Read the Data Sheet for Catalyst 6500 Series of Switches and the SNMP Configuration is this way:
In the following example, SNMP ifIndex persistence is enabled for all interfaces:
router(config)# snmp-server ifindex persist
In the following example, SNMP ifIndex persistence is enabled for Ethernet interface 3/1 only:
router(config)# interface ethernet 3/1
router(config-if)# snmp ifindex persist
router(config-if)# exit
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/ifindx.html
So what is the recommended way either its Globally or Every interface. Because normally we need give the command on Global and which provide
the snmp trap for whole Switch / Router. And another thing I didnt find that where we provide the IP Address of our Monitoirng Server?
So what will be the effect if we apply this command on Global Mode or every Interface Mode?
Rolf Fischer Wed, 07/03/2013 - 05:40
  • Blue, 1500 points or more
to my best knowledge, the only difference is the amount of memory needed.
Every single InterfaceName-to-InterfaceIndex Hash requieres 25 bytes in NVRAM.
c6509#dir nvram:ifIndex-table
Directory of nvram:/ifIndex-table
3  -rw-       13748                      ifIndex-table
c6509#more nvram:ifIndex-table
00000000:  0000001F 00000065 00000201 47696761    .... ...e .... Giga
00000010:  62697445 74686572 6E657433 2F323900    bitE ther net3 /29
You can define an ACL which only allowes your NMS and apply it to your community commands:
Switch(config)# snmp-server community cisco rw []
Hope that helps
Rolf
jahanzaib amin Wed, 07/03/2013 - 06:21
Dear Rolf,
Thanks, so we define stand access-list in which we mention the IP Address of our Solar Wind Server.
So here is full script for SNMP enabling on 6500: Please confirm that it is correct or not.
router(config)# snmp-server community cisco rw 10
router(config)# access-list 10 permit 10.10.10.80 0.0.0.0
Can you provide some link for this configuration related to 6500?
Rolf Fischer Wed, 07/03/2013 - 06:33
The Solar Wind Server is the only device which needs to have SNMP-access?
And if no write-access is needed, you can replace the "rw" with "ro" (read only).
What about traps?
You already found the configuration guide, are you looking for something in particular?
If you're looking for SNMP (all platforms), you find a lot of documents here:
http://www.cisco.com/en/US/partner/tech/tk648/tk362/tk605/tsd_technology_support_sub-protocol_home.html
c6500 support page:
http://www.cisco.com/en/US/products/hw/switches/ps708/tsd_products_support_series_home.html
Best regards
Rolf
jahanzaib amin Wed, 07/03/2013 - 23:47
Yes Solar wind Monitoring server need snmp enable as RO or RW.
Did my script is correct for enabling SNMP on 6500 ?
Thanks.
Rolf Fischer Thu, 07/04/2013 - 04:05
Since it's a server for monitoring, I assume that it doesn't need write access.
If so, best practice would be to configure only read access (for security reasons):
router(config)# snmp-server community cisco RO 10
If required, you can configure RO and RW independtly with different communities and/or ACLs.
Obviously you don't have a trap receiver, so your config should be adequate.
Best regards
Rolf
theboywhocriedwolf Wed, 07/10/2013 - 02:56
hello jahanzaib,
are you using the NPM of solarwinds? i would like to ask something regarding the wireless summary view.. because in my case.. i dont see any access point in my orion NPM..how did you manage adding node into the npm of the cisco router that you want to send snmp to npm?
thanks
Related Content
