Warning message
RADIUS Fallback Local account not working
Answered Question
Jul 3rd, 2013
Hi all,
I have a RADIUS server running on windows 2003. I am using cisco 2960 switch, everything is working fine but i need to test the local user account on the switch so that i dont lock myself out if the radius server is not available.
which command shall i enter to enable that ?
any help will be much appricated.
many thanks,
Kamran.
Correct Answer by kcnajaf@25070 about 4 years 1 month ago
If you look at my previous post i have asked you to remove the CONSOLE group from line VTY 0 4.
line vty 0 4
no login authentication CONSOLE
By the by how are you testing this? I mean how are you making radius server un reachable? Hope you already have a local username and password configured?
Najaf
Please rate when applicable or helpful !!!
Overall Rating: 5 (1 ratings)
Przemyslaw Konitz Wed, 07/03/2013 - 04:56
hi,
any logs? are u writing about administration access to switch or dot1x?
check docs about AAA on switch
second method is reached if the 1st is unreachable
aaa authentication login default group radius local
regards
kcnajaf@25070 Wed, 07/03/2013 - 04:58
  • Gold, 750 points or more
Hi Kamran,
How is your current aaa configuration looking like?
If you have console access to device you can check the local username and password using console as below.
aaa authentication login CONSOLE local
line console 0
Please ensure that you have a local username and password is configured/.
Hope that helps
Najaf
kamrannaseem Wed, 07/03/2013 - 05:56
Hi Najaf,
Thanks for your help.
what about if i want to ssh into my device ?
many thanks,
kamran.
kcnajaf@25070 Wed, 07/03/2013 - 05:59
The above suggestion was to test if local  credentials are working...
So now are you looking for how to enable ssh in to your devices? Or you want to test the how the radius fall back will work for ssh?
Sorry i didnt really get your question :-(
Najaf
kamrannaseem Wed, 07/03/2013 - 06:23
Hi Najaf,
Yes I want to have access to switch if the radius server is not available.
many thanks.
kcnajaf@25070 Wed, 07/03/2013 - 06:30
Hi Kamran,
Could you please share your exsisting aaa configuration?
If you want to test if your configuration is working, then try replacing the exsisting radius server ip (on your switch configuration through console) with a dummy ip address. Then radius server will not respond and then u can try ssh to device using your local credentials..Easiest way to make radius server un available other wise would be to shut the port where radius server is connected. In that case you will have trouble in accessing other devices if local logins are not working :-(
Najaf
kamrannaseem Wed, 07/03/2013 - 06:37
Hi Najaf,
aaa new-model
aaa authentication login VTY group radius local
aaa authentication login ssh group radius
aaa authentication ppp default if-needed group radius local
aaa authorization exec default group radius local
aaa authorization exec VTY group radius local
aaa accounting exec default start-stop group radius
many thanks.
kcnajaf@25070 Wed, 07/03/2013 - 06:42
Hi Kamran,
Try this
This will fall back to local authentication if your radius server is not reachable.
Hope you are not currently calling any specific group under your line 0 4. If it is there remove it...
Hope that helps
Najaf
kamrannaseem Wed, 07/03/2013 - 06:47
Hi Najaf,
The console bit u mentioned earlier should i remove that from aaa and from lines.
line con 0
line vty 0 4
access-class 1 in
transport input telnet ssh
line vty 5 15
access-class 1 in
many thanks.
kcnajaf@25070 Wed, 07/03/2013 - 06:49
Hi Kamran
Try this..
line vty 0 4
access-class 1 in
Hope that helps
Najaf
kamrannaseem Wed, 07/03/2013 - 07:00
Hi Najaf,
No its not letting me in through RADIUS.
Should i remove the following lines from my configuration:
line con 0
line vty 0 4
line vty 5 15
many thanks,
Correct Answer
kcnajaf@25070 Wed, 07/03/2013 - 07:08
line vty 0 4
Najaf
kamrannaseem Wed, 07/03/2013 - 08:32
Hi Najaf,
Thank you ever so much its working !!!
much appricated for your time.
how long you been working on cisco devices ?
kind regards,
kamran
Jatin Katyal Wed, 07/03/2013 - 06:03
  • Cisco Employee,
If you want to do SSH using local username/password
then add the same command what  Najaf suggested in the above post.
line vty 0 15
transport input ssh
exit
~BR
Jatin Katyal
**Do rate helpful posts**
kamrannaseem Wed, 07/03/2013 - 06:28
Hi jatin,
After using these commands i can not login to my switch through RADIUS. how do i remove them?
many thanks.
Jatin Katyal Wed, 07/03/2013 - 06:44
  • Cisco Employee,
line vty 0 15
transport input ssh
exit
The above config will not help you access the device with radius credentials. I did mention that if you want to SSH using local database so use local credentials from the device itself.
~BR
Jatin Katyal
kcnajaf@25070 Wed, 07/03/2013 - 16:04
Thanks for using the rating system and glad to know that it is working as expected. I have been with playing with Cisco for about 10 years now:-)
Najaf
