Warning message
Authenticating LMS 4.x Users via TACACS+ on ACS 4.1
Jul 4th, 2013
Hello Support,
I tried to authenticate the LMS 4.x Users via TACACS+ on ACS 4.1. But
unfortunately is not working!
On LMS 4.x i have created users and i have defined roles to the users. I have defined the Authentication Mode Setup for
TACACS+ on LMS 4.x.
On the ACS 4.1 I have created a NDG and i have added a AAA client to the NDG.
then i have created the same users on ACS 4.1 that are existing on LMS 4.x. But when i try to login on LMS 4.x, I can NOT login!
Please advice if i'm missing something!
Overall Rating: 5 (1 ratings)
Vinod Arya Thu, 07/04/2013 - 02:36
  • Cisco Employee,
Does LMS took the Tacacs+ mode successfully?? You need to add LMS on ACS and have the same secret key. Once successful, any user account in ACS should be able to log in into LMS as a guest user.
-Thanks
fender100 Thu, 07/04/2013 - 02:42
Yes! the Tacacs+ mode is successfully performed! But I can not login.......
Vinod Arya Thu, 07/04/2013 - 03:05
  • Cisco Employee,
What is the error you see in LMS when you use your AAA account user ID?? Check ACS if there is any logs for auth fail or auth request.
Currently are you loging in using admin account?
Vinod Arya Thu, 07/04/2013 - 03:06
  • Cisco Employee,
Please restart daemon manager once for Tacacs+ PAM take effect.
fender100 Thu, 07/04/2013 - 05:36
I have restarted the daemon manager but unfortunately i can not log in on LMS 4.x. i get the same error in ACS...keyMismatch
fender100 Thu, 07/04/2013 - 04:21
I'm getting the error in ACS about key mismatch....
I will restart the daemon manager
