Creating a country ACL
Answered Question
Jul 4th, 2013
ASA 5505 Sec Plus 9.0 OS
I want to create a country ACL that allows only US IP's through my firewall for certain ports. The problem is that the most up-to-date US IP list I can find contains 46000 lines! Even though some of these entries can be combined into larger blocks many of them can't because of just a few IP's (relatively) belonging to other countries. Even if I just use the /8 and /16 subnets that's still about 5800 network-object entries for the object-group.
Can I even have an object-group with 5800 entries? Would that slow down my ASA? Is there an easier way to do this?
TIA!
Correct Answer by Rick Morris about 4 years 1 month ago
The short answer is yes, but will you notice, maybe but I don't think it will hinder it too much.  To go through all the lines and find the match will require some CPU headroom.  I would add half of them and check the CPU.  Then add the rest and see what happens.  My guess, you should be fine.
Overall Rating: 5 (1 ratings)
Rick Morris Thu, 07/04/2013 - 10:51
  • Silver, 250 points or more
Blocking traffic with an ACL on the ASA could become very labor intensive.  One thing I have seen is third party products that can accomplish the same thing.  Here is one after a quick search that I was able to find.
https://www.countryipblocks.net/
alceryes3 Thu, 07/04/2013 - 11:02
Thx.
Yeah, that's actually where I got the 46000 line network-object list from. I don't want to add any more costs to my setup since it's just my home/dev environment. Do you think it would slow down my ASA if I had a 5800 object object-group in my ACL's?
Correct Answer
Rick Morris Thu, 07/04/2013 - 11:09
alceryes3 Thu, 07/04/2013 - 11:46
Thx Rick,
I was actually 10 minutes into my ASA accepting the 46000 network-objects from a copy-paste when I thought it may be a bit too much  .
I went ahead and entered the 5800 line /8 and /16 objects and will monitor performance.
As a side question. How do I skip a certain section when doing a show run, show access-list, or show object-group? Ideally, I want to skip that object group just created.
Edit - Using about 30MB more memory from the start. No difference in CPU.
I think this will work perfectly as my ASA isn't really doing much most of the time (except for when my FTP site gets intermittently slammed by reverse brute-force attacks from several different countries). I know it's the norm in this day and age but it still bothered me...problem solved  .
Rick Morris Thu, 07/04/2013 - 21:14
Depending on how you have the ACL set up you may have to use a filter.
For instance, when you do a show run and it stops at the first page type a / , yes a forward slash and then the statement.
ASA#sh run
/object xyz  <---this is not a very easy command to use since it just filters and stops at the first instance.
Another option is to do a show access-list | b line 1001  This will drop the show access-list to the specific line to start at and show the rest of the lines afterward as if you were going line by line.
I am not aware of any other way.
bascheew Tue, 04/18/2017 - 21:27
I know this is an old post, so I apologize for resurrecting it!
Using 'show running-config | exclude network-object', filters out the 6k line US-IP object-group perfectly.
I know the exclude command worked on ASA's, but on IOS I'm finding that "show run | exclude object-group" only removes the name of the object from the config and not the IP's in the object.  Does anyone know how to hide the object-group from the config, because it is several thousand lines long!
usasigcis Sun, 07/07/2013 - 12:10
is this a http policy?
i wonder if you can use regex to create a class-map > policy-map > service-policy to block the geo-location tags ???
that would be so much cleaner approach and less RAM intensive
alceryes3 Sun, 07/07/2013 - 13:14
It's for an FTP ACL. I am only allowing US IP's through to my FTP site. That definitely sounds more efficient. How would I set it up?
