Is there any option on Cisco Unified CM Administration 9.1.1 to show caller ID number when using MOBILITY option?
Answered Question
Jul 4th, 2013
Dear All,
I am using Cisco Unified CM Administration 9.1.1 and MOBILITY works fine.
However  when somebody calls from external phone number into internal user number and MOBILITY option is ON and obviously, forwards the call for the user's cell.....in this case user can see only main company number, but not a caller number.
So, is there any option to change it?
Thank you
Correct Answer by Jaime Valencia about 4 years 1 month ago
Go to the GW and run some debugs to find out exactly what you're sending, chances are, your telco is overwriting the original called number as it's nor part of your DID range.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 07/04/2013 - 13:57
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Sergey Lubenkov Sun, 10/13/2013 - 00:21
Hi Jaime,
You was right. GW sent to PRI correct data but telco blocked (by default) original number.
The issue was resolved after enabling on PRI the Screening Removal Feature.
Sergey
