Warning message
How to configure two cisco UCS manager in a cluster?
Jul 4th, 2013
Please provide the steps to configure two UCS manager in a cluster.
Thanks in Advance!!!
Thanks & Regards,
Shashi
padramas Fri, 07/05/2013 - 01:13
  • Cisco Employee,
Hello Shashi,
Two Fabric Interconnect ( FI ) make up the cluster or UCS domain and it is administered via single UCSM instance running on FI ( active primary role )
There is no additional software configuration required from user to build a UCS cluster.
The following doc will help you if you are setting up the FI for the first time.
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/gui/config/guide/2.1/b_UCSM_GUI_Configuration_Guide_2_1_chapter_0101.html
UCS docs
http://www.cisco.com/en/US/products/ps10265/products.html
Padma
shashi_kishor Fri, 07/05/2013 - 01:34
Hi Padramas,
Thanks a lot for the quick reply.
Actually i went through the configuration guide.
Below are the steps which is mentioned in guide, please find my query
Step 1 Connect to the console port.
     Query :please let me know how to open console port.
Step 6 On the Cisco UCS Manager GUI launch page. select Express Setup.
    Query :Not able to see Express Setup in UCS manager GUI.
Step 7 On the Express Setup page. select Initial Setup and click Submit.
     Query : Not able to see Initial Setup in UCS Manager GUI.
Shashi
padramas Fri, 07/05/2013 - 05:51
  • Cisco Employee,
Hello Shashi,
At UCS level, each UCS domain ( FI cluster ) is separate management entity and managed by UCSM.
With current version of UCS Central product, you can centralize certain management functions like global pools , monitoring etc.
Now, let us take a step back to understand your setup.
Is this brand new installation of FIs ?
Do you have physical access to FI ?
The guide provides instructions on initial set up process of UCS domain ( FI cluster )
If my understanding is incorrect, please provide more detailed information about requirement.
Padma
shashi_kishor Sun, 07/07/2013 - 23:43
Hi Padramas,
I have two Cisco UCS Emulator on two different machine.
Suppose Cisco UCSPE 1 is on machine A and Cisco UCSPE 2 on machine B.
Now my requirement is:
I want both the emulator is a cluster. That means we sholud have one URL to access both the emulator.If emulator Cisco UCSPE 1 is down then Cisco UCSPE 2 should connect automatically.
I did not install FI seperately, just after the installation of emulator   i have configured all the components manaually through UCSM GUI.
Thanks & Regards,
Shashi
