Warning message
GRE tunnel through asa no pptp, l2tp, ipsec
Jul 5th, 2013
Hello!
can't understand how to configure GRE tunnel through ASA
i have one router with public ip, connected to internet
ASA 8.4 with public ip connected to internet
router with private ip behind ASA.
have only one public ip on ASA with /30 mask
have no crypto
have network behind ASA and PAT for internet users.
can't nat GRE? cause only TCP/UDP nated(?)
with packet-tracer i see flow already created but tunnel doesn't work
Karsten Iwen Fri, 07/05/2013 - 11:43
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
You don't need any NAT if you can route your traffic. Just make sure that the outside router has a route to the private IP of the inside router and the inside router has a route to the public IP of the outside router. Then allow GRE in the ACLs of the ASA for these IPs.
GrimnirMsk_2 Fri, 07/05/2013 - 12:09
think internet providers won't want to route traffic to my inside router private ip.
even i write route thru internet to my inside router private ip
scheme
R1(public) - internet - (public) ASA (private) - (private) R2
Karsten Iwen Fri, 07/05/2013 - 12:24
oh, I thought your public router is directly in front of your ASA. there you wouldn't need any NAT.
With the router being remote, you can do a 1:1 NAT on the ASA for the internal IP.
GrimnirMsk_2 Sat, 07/06/2013 - 01:22
Karsten Iwen Sat, 07/06/2013 - 04:33
A "clean" way would be to use a protocol that can be PATted. That could be GRE over IPSec. With that you have the additional benefit that your communication is protected through the internet.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
