Warning message
Script to collect session integer.
Jul 6th, 2013
Dear All,
We are attempting to extract the  session ID from a phone call and convert the session format to integer. As we know, we have to extract
the hexadecimal session id and convert by using set step to convert as int.valueOf(SessionID.toString().substring(17,25), 16).
However, We're getting error when call come to this step. The error states: For input string: "ee6b2845"; nested exception is :java.lang.NumberFormatException: For input string:"ee6b2845" (line:1, col: 1) as capture. Any idea for solve it, would much appreciated.
Jonathan Schulenberg Sat, 07/06/2013 - 08:16
  • Cisco Designated VIP,
    2017 IP Telephony
Two thoughts:
  • I think you want Long.parseLong(SessionID, 16);
    http://stackoverflow.com/questions/11194513/convert-hex-string-to-int
  • Session, Document, and Contact variables seem to have special significance. I haven't had luck manipulating or carrying their values directly from one script to another. When it comes to sessions you can add a mapping ID which can be used to find the session later. The easiest one I have found that is reasonably unique to generate automatically is T[now].getTime()
Please remember to rate helpful responses and identify helpful or correct answers.
Gergely Szabo Mon, 07/08/2013 - 08:47
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
the ID of a session is of type... well, session. You cannot just cast it into Integer or int.
What are you trying to achieve, can you please give us more details.
G.
Related Content
