Warning message
Setting remote access on Cisco 888EA
Jul 8th, 2013
Hi all,
First, I apologize for my bad english. It's not my native language.
My problem:
I installed a new Cisco router (model 888EA) at my office. I want to create a remote acces to one of the computers in my LAN. Is someone know what are the commands for open some ports on the router (Apple Remote Desktop ports) and redirect the WAN IP to the computer IP in the LAN ?
If you need more infos or if you don't understand me, say it to me.
Thank you in advance for your help
Ben
Karsten Iwen Mon, 07/08/2013 - 04:44
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
You need to set up port forwarding for the ARD-ports and allow the traffic on the outside ACL.
A config for that could be like the following. Probably it has to be adjusted to your used interfaces:
interface Dialer1
  ! your WAN-interface
  ip nat outside
  ip access-group OUTSIDE-IN in
interface Vlan1
  ! your LAN-interface
  ip nat inside
! in this example 10.10.10.10 is the internal PC
ip nat inside source static udp 10.10.10.10 3283 interface Dialer1 3283
ip nat inside source static tcp 10.10.10.10 5900 interface Dialer1 5900
ip access-list extended OUTSIDE-IN
  permit udp any any eq 3283   ! ADR-Port
  permit tcp any any eq 5900   ! VNC-Port
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
