Warning message
Multiway
Jul 8th, 2013
I am unsuccessful in connecting a Multiway call.
I have the following equipment
4501 MCU with software 4.1
VCSE with software 7.2.1. The VCSE has an external IP address
TMSPE with software 14.2.2
I also have a
C40 with softwareTC4.1 ( I know it’s out of date)
3 E20’s with software TE4.1.1
EX60 with software TC5.1.1
All systems are registered to the VCSE and TMS
I can make multipoint calls to the MCU from any of the systems.
The endpoints all have Multiway enabled. The Multiway address in all endpoints is WNESU-Multiway. This alias does register to VCSE as a SIP alias:
<TR style="HEIGHT: 15pt" mcestyle="height: 15pt;">
<TD style="HEIGHT: 15pt; BACKGROUND: #f2f6f8; PADDING-BOTTOM: 0in; PADDING-TOP: 0in; PADDING-LEFT: 6pt; PADDING-RIGHT: 6pt; WIDTH: 347.25pt" width=463 mcestyle="height: 15pt; background: #f2f6f8; padding-bottom: 0in; padding-top: 0in; padding-left: 6pt; padding-right: 6pt; width: 347.25pt;">
Active
<TD style="HEIGHT: 15pt; BACKGROUND: #f2f6f8; PADDING-BOTTOM: 0in; PADDING-TOP: 0in; PADDING-LEFT: 6pt; PADDING-RIGHT: 6pt; WIDTH: 821.25pt" width=1095 mcestyle="height: 15pt; background: #f2f6f8; padding-bottom: 0in; padding-top: 0in; padding-left: 6pt; padding-right: 6pt; width: 821.25pt;">
true
<TD style="HEIGHT: 15pt; BACKGROUND: #f2f6f8; PADDING-BOTTOM: 0in; PADDING-TOP: 0in; PADDING-LEFT: 6pt; PADDING-RIGHT: 6pt" mcestyle="height: 15pt; background: #f2f6f8; padding-bottom: 0in; padding-top: 0in; padding-left: 6pt; padding-right: 6pt;">
Name
WNESU-Multiway
Protocol
SIP
Type
SIP UA
Authenticated
False
Node
DefaultSubZone
Vendor information
TANDBERG/4120 (X7.2.1)
Serial number
I have intentionally blanked out the address
Creation time
2013-07-07 16:51:38
Duration
4 hours 29 minutes 41 seconds
AOR
WNESU-Multiway
Contact
<A href="sip:127.0.0.1:2663;transport=tcp" mcehref="sip:127.0.0.1:2663;transport=tcp">sip:127.0.0.1:2663;transport=tcp</A></P></TD></TR>
Time since last refresh
0 seconds
Time to expiry
0 seconds
The VCSE has Conference Factory enabled with WNESU-Multiway as the Conference Factory Alias and [email protected] address of VCSE as the Conference Factory Template
I have an H.323 search rule of:
Priority: 48
Protocal: Any
Source: Any
Request must be authenticated: No
Mode: Alias pattern match
Pattern type: Regex
Pattern String: (99977\d+)@ip address of VCSE
Pattern behavior: Replace
Replace string: \1
I have a Neighbor zone created of:
H.323: Off
SIP: ON
Port: 5060
Transport: TCP
Accept proxied registrations: Allow
This entry has a search rule of:
Priority: 48
Protocal: Any
Source: Any
Pattern type: Regex
Pattern String: 999(77\[email protected] address of VCSE)
Replace string: \1
I can make calls from any of the endpoints to WNESU-Multiway and get to the MCU.
I can make calls from any endpoint to [email protected] address of VCSE  and get to the MCU
I can make calls from any endpoint to [email protected] address of VCSE and get to the MCU.
From my EX60 I dial the C40, then put the C40 on hold and dial one of the E20’s. I then press the Merge key on the EX60.
The EX60 displays a message reading
Merging calls
C40
E20
My EX60 connects with the MCU and I hear a message saying I am the first to join the conference. About 5 seconds later I see a message that reads Merging Calls Failed
 Thanks for any suggestions
Martin Koch Mon, 07/08/2013 - 08:09
  • Red, 2250 points or more
The pasted html stuff is quite hard to read.
I recommend that you check out the deployment guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Multiway_Deployment_Guide_X7.pdf
some quotes from it:
Note that:
And actually I do not get the thought behind your deployment anyhow and some info are missing
(like which target zone you try to use with your search rules, why you add a h323 only search rule for it,
how you configured multiway on the endpoints, ...)
Also the log from endpoints and the vcs (also search and call history & details for the attempts)
What I would do:
* read the multiway deployment guide
* read the multiway deployment guide again
* properly implement URI dialing and domains, especially if you want to use sip
* see that you get encryption working and thats currently only possible with h323 towards the mcu (if you need encryped content) anyhow, h323 to the mcu still feels like a good idea on vcs deployments also for the
* properly set up the multiway uri on the endpoints (try to prefix it with the protocol you use, like h323: or sip: and also manually set the protocol, I would use the call protocol which you use as the default)
* read the multiway deployment guide again :-)
Related Content
