Warning message
loadbalancing with Dual ISP
Jul 8th, 2013
Iam using ASA5510 and I want to configure my ASA to work with 2 ISP ( one with HTTP/HTTPS traffic - the second for all rest of traffic )
I know this is not a supported configuration but there is some workaround like i read on this post :
https://supportforums.cisco.com/docs/DOC-15622
I try the solution 2 : route traffic bases on destination ports with 2 default routes ( with metric 1 and 2) but it doesn't work!
I try to simulate this situation with packet tracert tool and when I send an http packet on the second WAN, the packet is still send on the 1st WAN link.
Is there someone who already success with this configuration ?
Thank you
I join my network schema to this post.
Jouni Forss Mon, 07/08/2013 - 09:23
Did you also use the NAT configurations in the document? They are the configurations that will actully redirect the HTTP and HTTPS traffic through the other ISP while naturally the secondary default route will also be required.
If you have ASA running 8.3 or newer software then it would be easier. Mainly because of the new NAT configuration format.
I have not tested this on 8.2 or older software.
- Jouni
avburren1 Tue, 07/09/2013 - 02:20
Yes I try all the solutions with NAT and default routes in the document and I have ASA running on 8.2.
Jouni Forss Tue, 07/09/2013 - 02:31
What does a "packet-tracer" commands output say when you try simulating a HTTP connection from LAN to WAN?
For example something like
packet-tracer input inside tcp 12345 1.1.1.1 80
If the NAT is configured correctly then you should see a UN-NAT Phase which should forward the connection through the correct ISP link.
- Jouni
avburren1 Thu, 07/11/2013 - 05:58
Here is the result of the command " packet-tracer input inside tcp 12345 1.1.1.1 80
We can see that the packet is forward through ISP1 and not ISP2 as I want.
Result of the command: "packet-tracer input LAN tcp 192.168.1.3 12345 2.2.2.2 80"
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         WAN
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (LAN,WAN2) tcp interface www 192.168.1.3 www netmask 255.255.255.255
match tcp LAN host 192.168.1.3 eq 80 WAN2 any
   static translation to 200.1.1.69/80
   translate_hits = 0, untranslate_hits = 0
Phase: 6
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (LAN) 1 192.168.1.0 255.255.255.0
match ip LAN 192.168.1.0 255.255.255.0 WAN any
   dynamic translation to pool 1 (WAN [Interface PAT])
   translate_hits = 5, untranslate_hits = 0
Dynamic translate 192.168.1.3/12345 to WAN/1025 using netmask 255.255.255.255
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 43, packet dispatched to next module
Result:
input-interface: LAN
input-status: up
input-line-status: up
output-interface: WAN
output-status: up
output-line-status: up
Action: allow
