Warning message
Is SNMP RW required to get response time?
Answered Question
Jul 8th, 2013
Hi guys,
My friend told me that there is a special function called "PMIB", which is needed for a Cisco switch to ping to its neighbor device
by itself and calculate the response time.
He also said that in order to do this, you need to set the snmp to RW and not RO.
For security purposes, I only want to allow RO, but I believe response time information is quite valuable and do not want to disable this option.
I googled to study more on this "PMIB" function by Cisco, but could not find any useful information regarding it.
Could anyone verify that this function does exist, and if RW is required?
Thank you very much
Correct Answer by Vinod Arya about 4 years 1 month ago
I think you are talking about Cisco-Ping-MIB. The Ping Group is part of the Cisco proprietary MIB under the Cisco Management branch (.1.3.6.1.4.1.9.9.16.). The Ping Group can be used to set up, perform, and retrieve Internet Control Message Protocol (ICMP) activity between remote devices from a management station.
Because this Ping group needs to be created and configured on the device, hence you need the RW access as well.
For more details please check:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8e.shtml
-Thanks
Overall Rating: 5 (1 ratings)
Correct Answer
Vinod Arya Tue, 07/09/2013 - 00:06
  • Cisco Employee,
-Thanks
Related Content
