Warning message
EIGRP "Flapping" every few days
Jul 9th, 2013
I've noticed that our eigrp routes are dropping and reestablishing every few days. I'm currently running a 2911 on MoE with our core router being a 3845. We have some MPLS circuits still up, which are on BGP with a redirect to the EIGRP.
Anyone find anything similar to this? I've looked around and tried debugging, but I've found nothing. Everything is set to default for hold times, and I'm not dropping any hello packets when I can check.
This is the constant message we get
000055: Jul  8 22:59:10.352: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 10.250.0.18 (GigabitEthernet0/0) is down: holding time expired.
The 2911's eigrp config
router eigrp 100
network 10.0.0.0
The 3845
router eigrp 100
redistribute connected
redistribute static
redistribute bgp 65400 metric 1500 10 255 25 1500
network 10.0.0.0
no auto-summary
router bgp 65400
no synchronization
bgp log-neighbor-changes
network 0.0.0.0
network 10.0.0.0
redistribute static
redistribute eigrp 100
neighbor 67.134.156.41 remote-as 209
no auto-summary
Thanks!!
Simon Brooks Fri, 07/12/2013 - 03:19
Debug ip eigrp
Sent from Cisco Technical Support Android App
blau grana Sat, 07/13/2013 - 02:27
  • Gold, 750 points or more
Hello Anthony,
Did you check link between routers? Maybe there is problem which cause EIGRP flaps.
You can temporarily configure IP SLA with low frequency (5s like EIGRP hello). Then configure tracking of IP SLA so you can see tracking changes in logs and compare them with EIGRP flaps.
Best Regards
Please rate all helpful posts and close solved questions
blau grana Sun, 07/14/2013 - 13:19
ip sla 10                                                        ! New IP SLA Instance #10   udp-jitter 10.1.1.1 16800 source-ip 10.2.2.2 codec g711ulaw    ! udp jitter w/Voice codec   tos 184                                                        ! TOS bit, using EF here   frequency 300                                                  ! testing interval ip sla schedule 10 life forever start-time now    - See more at:  http://routerjockey.com/2011/05/06/ip-sla-basics/#sthash.e6olXBbO.dpuf
ip sla 10
! ip address of neighbor
icmp-echo 1.1.1.1 frequency 5 ip sla schedule 10 life forever start-time now
track 1 ip sla 1 state
If EIGRP neighborship is flapping because of problem on link, you will see these messages in log output ->
%TRACKING-5-STATE: Up->Down
%TRACKING-5-STATE: Down->Up
Best Regards
Dinesh Kumar Ma... Sat, 07/13/2013 - 12:52
same msg me too getting... Hold down time expired... What are the reason for expiring hold down time...
paul driver Mon, 07/15/2013 - 05:39
  • Green, 3000 points or more
Can you show the output of  debug eigrp packet hello to see if the router is sending or/and recieiving eigrp hello messages
Ping the neigbour interfaces with small and then larger packets - Is this successful? ( possible congestion?
Ping 244.0.0.10 ( this is the Multicast address for eigrp hellos)
You can also try increasing the hold time to a higher value between neighbors, the default on broadcast interfaces 15 secs
interface x/x
ip hold-time eigrp xxx 60
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Related Content
