07-09-2013 06:27 PM - edited 03-16-2019 06:18 PM
Hi All,
I have a customer who is currently on a CME system, they then purchased a CUCM.
The CUCM is running in parallel to the CME, with a small number of users migrated from CME to CUCM.
The CME is configured as a h323 gateway in the CUCM.
There are dial-peers in CME to point to the CUCM for those users that have been migrated.
Calls between the systems are fine.
Is there a way of sending or receiving the alerting names of the users on the different systems? An extra command under the voip dial-peers perhaps?
When I call between 2 CMEs I see the alerting names between them.
Felix
07-09-2013 07:33 PM
CUCM should be seeing the CME names by default. For CME to get names from CUCM through H.323, make sure you have "
07-10-2013 10:39 PM
Getting customer to test this, will let you guys know.
Thanks for the prompt responses
07-09-2013 07:34 PM
Is "Display IE Delivery" checked on the H323 GW in CUCM?
Chris
