VC connect issue Lifesize over Cisco 1941 router
Jul 10th, 2013
We have a problem getting a gateway to register on a Lifesize VC unit. It was working fine over a Juniper but moved office and setup a Cisco 1941 as router/firewall to replace the Juniper and it is no longer able to register whatever we try to do.
the lifesize is LS_Ex1_4.7.21(4)
the relevant Cisco IOS config items on the 1941 are here:
ip inspect name FW-Video tcp
ip inspect name FW-Video udp
ip inspect name FW-Video icmp
interface GigabitEthernet0/1.150
encapsulation dot1Q 150
ip address 10.1.150.1 255.255.255.0
ip access-group video_out out
ip nat inside source static 10.1.150.3 public_ip_address
ip access-list extended video_out
permit udp any 10.1.150.0 0.0.0.255 eq 1719
permit tcp any 10.1.150.0 0.0.0.255 eq 1720
permit tcp any 10.1.150.0 0.0.0.255 eq 1718
permit ip 10.10.10.0 0.0.0.255 any
permit tcp any 10.1.150.0 0.0.0.255 eq 443
permit tcp any 10.1.150.0 0.0.0.255 range 60000 60013
permit udp any 10.1.150.0 0.0.0.255 range 60000 60055
any suggestions would be appreciated, the Gateway support have not been able to resolve it and neither the Cisco engineers I usually use.
paolo bevilacqua Wed, 07/10/2013 - 18:41
  • Hall of Fame,
    Founding Member
probably inconptete config, but to start with you need "ip nat inside" under interface.
However cases like this are, in my opinion, only solvable with direct access by a certified engineer.
markberry666 Wed, 07/10/2013 - 19:06
I have had certified engineers looking at it, hence my putting it out here.
sorry I shoudl have added more in but 'ip nat inside' is on the interface
we can access the VC from external and all testable ports appear to be working and translating across to the VC unit that is why its a mystery. We can even make calls out to other numbers but just cant get it to register with the gateway.
I hoped someone would have been through this with Lifesize VC's versus Cisco and could provide an answer.
mrmatthew77 Fri, 07/12/2013 - 15:25
Mark,
You may try disabling the Inspect policys.  I have seen this cause issues with registrations in the past. Also what type of gateway are you registering to?   Is this an h323 gatekeeper?
Are you seeing any replies from the gateway?   If so is it rejecting the registration or what is it replying with?
markberry666 Sun, 07/14/2013 - 17:16
I removed the h323 policy but I was advised this is needed to all ip address info to be passed on. Disabling the firewall all together is not an option.
The gatekeeper is h323 based and apparently uses udp 1719 for registration.
I am escalating this with some Cisco engineers so hopefully will get a solution . It does appear to be an issue with the Cisco h323 firewall not playing well with others at the moment.
markberry666 Sat, 07/20/2013 - 16:30
We are on the point of moving to ADSL for the VC and a non-cisco router for it, but I still want to understand this problem as it will stop me using CIsco in the future otherwise for VC units.
what we have seen is that the NAT appears not to be working. from this support post
https://supportforums.cisco.com/thread/2101730 I see that the issue has possibly arisen before for other IOS versions and it may be we have the same problem as described here.
our Cisco 1941 is using  IOS  C1900 software (c1900-UNIVERSALK9-M) Version 15.0(1)M3 release fc2
when we do sh ip nat translations for the relevant 10.1.150.3 VC unit address we are seeing udp for 1719 get just dashed lines and no ip address for outside local or outside global. Also the VC unit is not picking up the NAT public address but only showing itself on screen as 10.1.150.3. Though NAT is working for TCP as I can get into it via the public ip address using port 443 or port 80.
Related Content
