CCSIP Debug doesn`t show any output
Jul 10th, 2013
Hi - I`m having a peculiar issue with Cisco 2901 running c2900-universalk9-mz.SPA.152-4.M4.bin. The CUBE is configured to register with the carrier & it fails to register. It doesn`t seem to be attempting to send the register messages ,even. When I happen to run the debug CCSIP all , I don`t see any messages at all. Below are the output extracts from the CUBE.
Router#sh sip-ua service
SIP Service is up
Router#sh sip-ua statistics
SIP Total Traffic Statistics (Inbound/Outbound)
    Invite 0/0, Ack 0/0, Bye 0/0,
    Cancel 0/0, Options 0/0,
    Prack 0/0, Update 0/0,
    Subscribe 0/0, Notify 0/0, Publish 0/0
    Refer 0/0, Info 0/0,
   Register 0/0
Retry Statistics
    Invite 0, Bye 0, Cancel 0, Response 0,
    Prack 0, Reliable1xx 0, Notify 0, Info 0
    Register 0 Subscribe 0 Update 0 Options 0
    Publish 0
Router#sh runn | sec sip-ua
sip-ua
authentication username <removed> password 7 <removed> realm xxxxx.com
no remote-party-id
retry invite 2
retry register 10
retry options 2
timers connect 100
registrar dns:west.xxxxx.com expires 3600 auth-realm xxxxx.com < Tried IP address as well - NO LUCK , however the name resolution works fine & no routing issue found>
sip-server dns:west.xxxxx.com
Router#sh runn | sec voice
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  video screening
Could somebody advise ,if you have seen this kind of issue ?
Raj
Daniele Giordano Tue, 07/16/2013 - 02:37
  • Gold, 750 points or more
Do you have logging buffer enabled?
You can use
configure terminal
logging buffered [size]
to enable the logging buffer.
By default the output from system messages and debug is sent to a logging process.
So enable debug using
term mon
debug ccsip messages
Regards.
rajasekarvs Tue, 07/16/2013 - 05:08
Thanks for your response. The issue had been resolved by adding the credentials under the Sip-ua config set.
Raj
