How to communicate between layer2 switches in a intervlan?
Answered Question
Jul 11th, 2013
Hereby i attached my packet tracer of my disscussion.
i cant able to communicate or telnet between the layer2 switches from the respected vlan ports.
Pls help my need.
advance thanks for ur solution.
Correct Answer by InayathUlla Sharieff about 4 years 1 month ago
Chandhuru,
I made some changes and it working now.
Kindly configure the following and you should be able to ping and telnet to the switches between the layer 2 switches.
1- Remove the Vlan 1 configuration and configure vlan 10 and 20 respectively on the Core switch.
3560:
GigabitEthernet0/2     unassigned      YES unset  down                  down
Vlan1                  192.168.1.1     YES manual up                    up
Vlan10                 192.168.10.1    YES manual up                    up
Vlan20                 192.168.20.1    YES manual up                    up
b- Switch 2960- A
Vlan10                 192.168.10.2    YES manual up                    up
Switch#
c- Switch 2960 -B
Vlan10                 192.168.20.2    YES manual up                    up
Switch#
Make sure the port is trunk and its negotiated.(Switchport mode trunk, Switchport trunk encapsulation dot1q,)
Telnet configuration:
Switch 1 & Switch 2
Switch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#username cisco password cisco
Switch(config)#enab
Switch(config)#enable se
Switch(config)#enable secret cisco
Switch(config)#line vty 0 4
Switch(config-line)#lo
Switch(config-line)#logi
Switch(config-line)#login local
Switch(config-line)#pas
Switch(config-line)#password cisco
Switch(config-line)#end
Switch#
Switch#telnet 192.168.20.2
Trying 192.168.20.2 ...Open
User Access Verification
Username:cisco
Password:
Switch>en
Password:
Switch#exit
I just tested and its working fine now.
Inayath
******plz rate all usefull posts.**********
Overall Rating: 5 (1 ratings)
Correct Answer
InayathUlla Sharieff Thu, 07/11/2013 - 03:32
  • Cisco Employee,
Chandhuru,
3560:
b- Switch 2960- A
Switch#
c- Switch 2960 -B
Switch#
Switch 1 & Switch 2
Switch#conf t
Switch(config)#enab
Switch#
Username:cisco
Password:
Switch>en
Password:
Switch#exit
Inayath
