Warning message
802.11N (a-msdu / a-mpdu)
Jul 11th, 2013
For voice application Cisco recommends disabling packet aggregation, How i can disable this ? and there are some limitation after disabling ?
this is the command :
config {802.11a | 802.11b} 11nsupport {a-mpdu | a-msdu} tx priority {0-7 | all} {enable | disable}
Amjad Abdullah Thu, 07/11/2013 - 03:53
  • Red, 2250 points or more
This is the exact command that you need to use.
The throughput with the aggregation is a bit higher than that without aggregation.
Amjad
Rating useful replies is more useful than saying "Thank you"
