Warning message
VLAN ACL Question
Answered Question
Jul 12th, 2013
Hello Community,
I am currently studying for the CCNP SWITCH exam and had a question about how VLAN ACL's operate in a specific instance. The book is not clearing it up for me:
If I had the following configuration:
VTP-Server-1(config)# ip access-list extended ALLOW-TCP
VTP-Server-1(config-ext-nacl)# permit tcp any any
VTP-Server-1(config-ext-nacl)# exit
VTP-Server-1(config)# ip access-list extended ALLOW-UDP
VTP-Server-1(config-ext-nacl)# permit udp any any
VTP-Server-1(config)# ip access-list extended ALLOW-IP
VTP-Server-1(config-ext-nacl)# permit ip any any
VTP-Server-1(config)# vlan access-map MY-VACL-MAP 10
VTP-Server-1(config-access-map)# match ip address ALLOW-TCP
VTP-Server-1(config-access-map)# action forward
VTP-Server-1(config-access-map)# exit
VTP-Server-1(config)# vlan access-map MY-VACL-MAP 20
VTP-Server-1(config-access-map)# action drop
VTP-Server-1(config)# vlan access-map MY-VACL-MAP 30
VTP-Server-1(config-access-map)# match ip address ALLOW-IP
VTP-Server-1(config)# vlan    filter map VLAN-22-MAP vlan-list 22
Would TCP traffic be allowed to pass and all other traffic dropped since there is no specific ACL being matched to "MAP 20"? Would the filter ever get passed the second map "map 20" in this case? Im confused as to what would actually happen in this case. The book has conflicting entries about what actions would be taken since the second entry has no ACL matched to it. It says in the first part that "Because  no ACL is specifically matched in sequence 20, all traffic that  is not dropped  in sequence 10 is effectively forwarded." But at the end in the chapter quiz it marks me wrong when I say the traffic will be forwarded, its states that IP and UDP traffic will be dropped.
Thanks.
Chris.
Correct Answer by Eduardo Aliaga about 4 years 1 month ago
Hello Chris
Since MY-VACL-MAP-20 didn't specify a match , then it will match everything. That means the chapter quiz is correct, all IP and UDP traffic will be dropped.
For reference you can see the following links
http://blog.ine.com/2009/08/10/vlan-access-control-lists-vacls-tiers-1/
https://learningnetwork.cisco.com/thread/37041
Please rate if this helps
Overall Rating: 5 (1 ratings)
Correct Answer
Eduardo Aliaga Sun, 07/14/2013 - 00:04
  • Silver, 250 points or more
Hello Chris
Craddockc Mon, 07/15/2013 - 09:29
Eduardo,
Thank you so much for the clarification!
Chris.
Craddockc Tue, 07/16/2013 - 14:37
Eduardo,
I know this seems intuitive, but since sequence 20 matches everything, does it stand to reason that the map filter will never get passed sequence 20 and on to sequence 30 etc? I would venture to say that it doesnt since all packets are matched in sequence 20. Thanks.
Chris.
Trending Topics - Security & Network
